Old 02-19-2004, 02:10 PM
bevan bevan is offline
Rep: 10 Posts: 16
material
I need to produce a plug to make a mould. Can anyone think of a material besides wood and metal.
Thankyou
Old 10-08-2004, 03:10 PM
Rep: 66 Posts: 640
Thankyou
Foam is a good option.
Dutch Peter
Old 10-09-2004, 02:31 AM
Rep: 2891 Posts: 8,795
If it's a one off mold then you can use anything that will hold it's shape, support the weight of the laminate during cure, be reasonably inexpensive, reasonably easy to work into a fair surface and tolerate some heat during the cure.
Old 10-13-2004, 03:39 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
Foam as mentioned, concrete springs to mind, clay, plastic...actually, some plastics are lousy....
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 10-15-2004, 05:21 AM
David Cowen David Cowen is offline
desperock
Rep: 10 Posts: 24
Hardboard is what I am going to use. It has one lovely shiny surface that can take polish pva etc and its only £2 a sheet over here. Give it some ply as a former and your off!!
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 05:00 PM
Option One - how big Willallison Option One 43 12-20-2005 06:44 AM
boat material / furniture material bogeyinthekeys Materials 7 09-10-2005 09:29 AM
Best material for freestanding hull (suggestions?) ntrabbit Fiberglass and Composite Boat Building 5 05-25-2004 12:12 PM
Plywood material properties Archive Materials 2 06-12-2001 05:01 AM
