Old 07-26-2010, 09:49 PM
rugludallur's Avatar
rugludallur rugludallur is offline
Rugludallur
Rep: 235 Posts: 81
Masking for Sandblasting
I wonder if those of you with experience in sand/slurry/soda blasting can share any tips on masking/covering/protecting areas.
From what I understand rubbery materials are best in order to "bounce" grit/shot off, for smaller grit and stencil work I noticed a lot of people use vinyl tape ranging from 0.2-0.4mm but what about larger grit/shot and more heavy duty blasting?
For my current project I'm contemplating using rubber hoses for railing/tubes/pipes and for larger items air tubes from car/bicycle tires along with vinyl tape.
What do you guys use when you have mirror finish stainless welded to structures that need to be blasted?
Jarl
http://dallur.com
Old 07-26-2010, 11:05 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
Sheet rubber, sold as swimming pool/garden pool liner. About 70 cents a square foot.
sandblasting a wooden boat pduhglas Wooden Boat Building and Restoration 20 09-19-2011 09:10 PM
Sandblasting antifouling simon Fiberglass and Composite Boat Building 17 12-24-2009 03:39 AM
How much for sandblasting? filiperosa Metal Boat Building 2 05-31-2007 06:52 AM
Sandblasting from the water line on down only. AdamFrench Metal Boat Building 3 05-24-2007 04:16 PM
Sandblasting - or? yago Metal Boat Building 29 10-23-2005 06:31 AM
