Old 03-30-2007, 03:43 PM
Mikey2 Mikey2 is offline
Rep: 10 Posts: 17
Manufacturing Aluminum Masts
Hi.
I am doing an assignment into the mast and the materials used and the manufacturing process and have a few question I hope you can help me with.
1. What Alloys are added to the Aluminum masts if any?
2. On larger masts the top is tapered, is this done by hand once the mast has been extruded? Or is this done by a different process?
3. Does anyone know of the quality control checks that would be carried out when manufactured?
Thanks.
Old 03-31-2007, 05:11 AM
Rep: 756 Posts: 3,328
Masts are EXTRUDED one piece usually from 6061T6.
They are hand cut and welded to taper the top.
BIG factory required for extrusion process!
FF
Old 03-31-2007, 07:11 AM
Rep: 10 Posts: 17
Thanks for your response.
Does anyone know of the treatments carried out once extruded?
I read somewhere they are primed and top coated using Awlgrip polyurethane finishes...
Old 03-31-2007, 07:33 AM
Greybarn Greybarn is offline
Rep: 10 Posts: 57
The treatment depends on the application. If the masts are for one-design boats, then they are typically anodized. In the old days, (15 years ago), if the mast was for an ocean-going racing sailboat, then no extra paint was applied as it added unnecessary weight. If the mast were for a yacht, then the aluminum would be painted with some sort of linear polyurethane paint (Awlgrip, Imron) and would be prepped accordingly (alodine wash, zinc chromate primer, undercoat, LP paint).
Old 03-31-2007, 07:36 AM
Rep: 10 Posts: 17
O rite thanks. Would this be done by hand, or would it be sprayed on automatically once extruded?
Old 03-31-2007, 07:40 AM
Rep: 10 Posts: 57
This would be done by hand after all the fittings have been fit to the mast. All of the fittings are drilled and tapped, countersunk etc,the winch pads are attached, the mast is tapered, and welded. everything is then taken off hte mast and then paint procedure is started.
Old 03-31-2007, 08:49 AM
Rep: 10 Posts: 17
Does anyone know of the quality control checks carried out?
Also when you say everything is taken off? I read somewhere that it is difficult to weld when the mast is given its final treatment? Or are the fittings attached another way?
Old 03-31-2007, 09:49 AM
RHough's Avatar
RHough RHough is offline
Retro Dude
Rep: 714 Posts: 1,622
Masts are not usually welded after they are anodized. If the mast is tapered, it gets tapered before it is anodized. Tanks big enough to anodize masts are fewer and farther between than they were 10-15 years ago, so more masts are painted these days.
When we taper a section that has been anodized, it gets painted after the taper is welded. The same goes for any welded repairs. A good weld requires clean metal, so the anodized surface must be ground off before welding. The welded joint should be protected by a new surface treatment. Paint is more practical than having the mast anodized again.
Proud supporter of The Far Kurnell Cat Racing Team
I have not failed. I've just found 10,000 ways that won't work.
- Thomas A. Edison
Old 03-31-2007, 10:15 AM
Rep: 10 Posts: 17
So from what I've learnt, the process goes as following...
  1. Aluminum 6061T6 Billets are melted down and extruded through the mast cross section die.
  2. The extrusion is then cut to the length required.
  3. The top end would be cut and tapered and welded.
  4. Any other holes and fixings would be cut out.
  5. The mast would then be anodized.
  6. Mast would be prepped (alodine wash, zinc chromate primer, undercoat, LP paint).
  7. Final finish coat applied: Awlgrip.
  8. Any screw holes chased.
And thats how a mast is manufactured. Is this correct? Have I missed something? Or got something wrong?
Old 03-31-2007, 10:41 AM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
http://www.dwyermast.com/
Tech support?
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Old 03-31-2007, 01:26 PM
# Aluminum 6061T6 Billets are melted down and extruded through the mast cross section die.
The mast builders usually OWN the die for the extrusion ,(not the extrusion shop) so the sections are trimmed to their requirements.
# The extrusion is then cut to the length required.
Owning the die allows some competition to lower costs , and some roll the sail into the mast extrusions are 2 parts or more and the result is a really heavy mast.
FF
Old 03-31-2007, 02:19 PM
Rep: 10 Posts: 17
This I understand
This I don't understand, why would you put the sail in the mast? The only thing I can see is it saves space in the factory...
Old 03-31-2007, 03:49 PM
ted655's Avatar
Rep: 122 Posts: 641
Like a window shade. Alot of light, or a little light. Same with wind. Most are operated from the cockpit or cwheelhouse. Great for large boats with few crew or single handing.
Also gives UV proyection when at docked.
Old 03-31-2007, 07:23 PM
allan white allan white is offline
Rep: 18 Posts: 22
Mikey2,
A minor clarification is that aluminum is not actually melted prior to the extrusion process. I believe it is heated to +- 900F and then pushed thru the die by an extremely powerful hydraulic press.
allan
Old 04-01-2007, 12:28 PM
Rep: 10 Posts: 17
Ah, Ok thanks.
The primer coats and final finish, is this applied by brush? Sprayed on?
Manufacturing Engineers needed dereksireci Services & Employment 0 01-28-2005 02:55 PM
GS Manufacturing Chopper Gun awake4air Marketplace 0 12-01-2004 04:12 PM
Best hull manufacturing method Tom_McGuinness Fiberglass and Composite Boat Building 19 11-22-2004 02:01 AM
Aluminum masts: mechanical properties Gades Boat Design 3 09-09-2002 09:07 PM
Manufacturing ENG looking for work cprowler Services & Employment 0 06-01-2002 06:27 PM
