  #31
Old 04-22-2007, 10:24 AM
Mikey2 Mikey2 is offline
Rep: 10 Posts: 17
^^ Agreed.
  1. Aluminum 6061 Billets are melted down and extruded through the mast cross section die.
  2. The extrusion is then cut to the length required.
  3. The top end would be cut and tapered and welded.
  4. Any other holes and fixings would be cut out.
  5. Then it is heat treated and quenched.
  6. The mast would then be anodized.
  7. Mast would be prepped (alodine wash, zinc chromate primer, undercoat, LP paint).
  8. Final finish coat applied: Awlgrip.
  9. Any screw holes chased.
How about that then?
  #32
Old 04-22-2007, 03:18 PM
lazeyjack
only around the taper, there should not be any welding elsewhere
Al Al loses abt 60 % of its strength abt the weld areas
  #33
Old 04-22-2007, 03:24 PM
lazeyjack
you seem very intense abt this, what are your goals, ?
  #34
Old 04-22-2007, 04:22 PM
Rep: 10 Posts: 17
I'm doing an essay on the production of the mast, looking at the manufacturing methods used, and the quality control checks carried out.
Thank you for your help so far, if you have any info on quality control checks carried out then please post
  #35
Old 04-22-2007, 05:01 PM
lazeyjack
well there are the bend tests, which consist of rolling the metal around a certain diameter, the radii of which is the thickness of the metal x a factor, and I can't remember what that is, plus the standard hardness tests All this should be freely available on various sites, try alcan , perchinay, then the test cert will give the exact proportions in % of each metal, like Ni, CadmiumChrome, magnesium and others It will give the tensile achieved, which must fall within a range
  #36
Old 04-23-2007, 01:40 PM
Rep: 10 Posts: 17
Ok thanks, how often is this done? every one in 20?
Anymore?
  #37
Old 04-23-2007, 08:08 PM
Gramp34 Gramp34 is offline
Rep: 10 Posts: 12
Originally Posted by Mikey2 View Post
^^ Agreed.
I'd suggest reading about the extrusion process, e.g., at http://www.bonlalum.com/Login/SlsMfg...on_process.jsp, to better understand how the extrusion part is done.
Read up on the heat treatment of aluminum, as well.
Machining is straight forward: sawing, drilling of holes and milling of slots, probably with a woodworking router.
I doubt any heat treatment is done except when the initial extrusion is made. Yes, welding will reduce the strength of the mast in the heat affected zone immediately around the welds, but the welds on tapered masts carry very little load.
Finish is either anodizing or painting. Awlgrip is LP paint.
Quality control of the mast extrusion will be primarily the responsibility of the extruder. They make sure the right alloy is provided, then would certify the mechanical properties (tensile strength, hardness) and dimensions of the extrusion are correct. The sparmaker would need to verify the mast has been made correctly to the customer's engineering drawing, for instance, that hardware is mounted in the correct places, before it is shipped to the customer. If the material has the correct properties and the shape of the parts are correct, there is no need to destructively test (i.e., break) sample masts.
You're in the UK? Why don't you phone (ring up?) some sparmakers there? For instance, look at http://www.zsparsuk.com. They invite people to visit. I'm sure they'd be happy to explain the process to you.
Good luck,
Tim
Manufacturing Engineers needed dereksireci Services & Employment 0 01-28-2005 02:55 PM
GS Manufacturing Chopper Gun awake4air Marketplace 0 12-01-2004 04:12 PM
Best hull manufacturing method Tom_McGuinness Fiberglass and Composite Boat Building 19 11-22-2004 02:01 AM
Aluminum masts: mechanical properties Gades Boat Design 3 09-09-2002 09:07 PM
Manufacturing ENG looking for work cprowler Services & Employment 0 06-01-2002 06:27 PM
