| Making a keel bulb mold from concrete Is there anything special about a concrete mix for making a multi pour mold? I know to reinforce it with wire cloth and rebar. I know to cure it wet for 10 days and then dry cure it for 10 more days. I warmed the last one I built before pouring the lead into it. It looks pretty worse for wear just after 2 pours. Thanks in advance for any input. Sam
__________________ __________________________________________ We build Mini's www.thirdcoastcomposites.com |
| Concrete has a bad habit of containing some water in. When heated (like in lead pouring) it (water) expands and pretty much destroys the concrete. Drying concrete is a PITA.. |
| I'll second that Teddy, in that an uncoated concrete mold scares the hell out of me. This said, it could be coated to lock down the moisture (which will remain for decades in concrete) with something like the stuff they use on the inside of pottery kilns. This will not burn off from the pour and isolate the moisture in the concrete from the molten lead. |
| When I did the earlier pour I used water glass to coat the interior of the mold. I didn't have any problems, but I think I over heated the mold with a propane torch. (Lead continued to 'gas' off after the pour into the mold.) (I know not to breath this stuff and neither should anyone else.) Sam
| Keel Bulb Casting | JohnMc | Press Releases | 2 | 01-14-2008 11:07 PM |
| Retractable bulb keel | brevell | Boat Design | 0 | 05-26-2005 04:40 PM |
| new bulb keel | mod flod | Boat Design | 8 | 01-30-2005 12:25 AM |
| keel bulb design - help | garofaloj | Sailboats | 17 | 01-14-2005 12:36 PM |
| Adding a bulb to keel | Laser28 | Sailboats | 27 | 10-22-2004 10:52 AM |
