| LP gas tanks I know this topic has been touched a few times in other threads but I’m looking for a little more detail. I have used LP gas in campers for years without a problem. Checking for leaks is simple and general good maintenance keeps trouble from happening. I want to use it for heat and cooking on a boat. Are there codes and regulations governing the installation of a LP system on a boat? Gary
__________________ "The hand feeds the mind." Weston Farmer |
| ABYC is always a good place for safety guidelines. There are no codes or regulations, but a manufacturer or designer would probably face some liability if the ABYC guidelines were ignored. The USCG does have some regulations for commercial/charter vessels I believe. http://www.abyc.com/standards/toc.cfm American Boat and Yacht Council (ABYC) - Standards and Technical Reports: Table of Contents DC |
| A1, MARINE LIQUEFIED PETROLEUM GAS (LPG) SYSTEMS Right at the top. Thank you, DC Gary
| Another reference is the NFPA pamphlet 302 chapter 6-5. I happened to just have read this last week. Kyle |
| LPG on boats Quote:
I plan to use LPG on my power boat for both cooking and hot water. The tanks will be located in the after cockpit seat lockers. The lockers will be vented directly outboard through the hull. Automatic shut off solenoids are being seriously considered as an additional safety feature. I have considered opening the bottoms of the lockers to the cockpit sole for ventilation and water drainage but since LPG is heavier than air this may not be a good move. Any feelings about opening the locker bottoms? Bill Buchanan |
| "I have considered opening the bottoms of the lockers to the cockpit sole" Not a good idea. You should have a safe set up if you follow the ABYC guidelines. Insure that all leaks drain or vent overboard at least 20” from any hull openings. Gary
| Visit Tridentmarine.com. They have a series of products for lp gas use on boats. you might find them to have something that fits your needs.
__________________ JORGE LANG DEANGELO MARINE EXHAUST |
| Thanks for the link Jorge. Gary |
| Portager will cringe I'm sure ( ) but I love gas! We've cooked and heated with it for almost my entire life without drama. There are safety issues that must be considered however. Solenoids, gas detectors etc are great but the 3 most important things to remember when using LPG are:1. ALWAYS vent cylinder storage areas directly outboard from the lowest point of their 'cupboard' 2. A small amount of flow-thru ventilation is required to ensure you don't quietly drop off to sleep (forever) 3. Like the rest of you boat, maintenance is the name of the game. Something else to consider, fibreglass gas cylinders are becoming more readily available. Not cheap, but it certainly sidesteps the problem of corroding cylinders...
| Hot water, heaters, cookers..... | Willallison | Option One | 41 | 11-16-2009 05:59 PM |
| Installing LPG in boats in America. | tom kane | Open Discussion: All Things Boats & Boating | 50 | 07-23-2007 11:42 PM |
| Gas vs. Diesel torque comparison | Chuck Bates | Propulsion | 12 | 09-04-2005 10:25 PM |
| New menber lost | ebb | Sailboats | 4 | 05-31-2005 04:34 PM |
| gas tank building | bushbunny | Boatbuilding | 12 | 11-14-2003 11:04 AM |
