| looking to build aluminum cat need help? Hi everyone ; i'm looking to build aluminum catamaran and would apreciate any help,from leads of asian builders ,to best size /design for long term cruising/methods of construction/grade of aluminum and thickness,and is anyone building a aluminum cat in the u.s. I do have the basic plan of a 48 by 24 but will listen and apreciate any help and sugestions ..thank you.. |
| Try Silkline catamarans. http://www.silkline-catamarans.com/ Looks a lot like a cat i'm building, a Simpson Slipstream 15 Pics of Silkline and a Simpson Dave |
| thanks for reply. I already had checked Silkline and a couplle others and find some of their ideas great and of valuable help.are you building a aluminum Simpson Slipstream 15? out a kit or of plans ?where you buy your aluminum ,what grade,price?........any help greatly apreciated..thank you. |
My point being is that Simpson never did a 15m alloy cat so Silkline may have massaged the drawings [nothing new in this] Dave |
| Theres a bloke in Perth --Auss called Gavin Meyer I think thats how you spell it. Big web site and ships flat packs all over the world. Try a google but you might have to play with the spelling. I think Im right in saying he can ship a whole boat in a box. |
| Thanks for the lead marinekits does gives a lot of info ,with some very nice options,the price of 130k just for a flat kit for a 44by 24 cat is high but an option they do give you some valuable tecnic info.... what you think of their 5mm bottom hull it looks border line to me ,i was thinking more on 7/8 mm for bottom and 5mm for the rest .... again my sincere thanks for taking the time to helping ,being new at this i'm all ears. |
| I personally dont think ally sailing cat's come into there own untill you get over 55 feet as its just too bloody heavy. you don't want to make it any heavier by adding more ally than speced. the killer of multi's is weight, for $120k in a kit what about a composite boat http://www.fusioncats.com/home.html http://www.schionningdesigns.com.au/www/welcome.cfm Dave |
| Thank you DAVE, i know that composite is the way to go for a lot of people but when safety and low maintenance is factured in, even if you can be a couple tons heavier aluminum is hard to beat i,ve heard one to many problems with composite ,and believe me i have no bias i just listen to both sides , problems with one and the other and it apears that for a long term cruising aluminum has the edje acording to the majority of veterans i've heard from.i greatly apreciate your leads and taking the time to help even if i,ve not decided how and where to buid i think that aluminum will be my first choice.....k |
| Interesting....... I did my apprenticeship building 100'+ gin palaces out of alloy in the 80's and have mates that i did my time with still building alloy boat's for clients, yet we all build composite boat's for ourselves. Infact, I believe you will find in real life that safety and maintenance swing's in composite's favour, unless of course you start making a habit if smacking into thing's. And how many of these veterans are there sailing alloy cat's. An alloy mono is one thing, I would go alloy over composite, but in a cat, no contest. Good luck in your new boat, Dave |
| has you said interesting.!....and it does make you think....but you been an expert in this things and knowing both methods well i'm surprised you will go composite but what do i know.... but one thing is for sure i do intend to smack into things or expect they to smack into me ... ........................once again thank you for your insight and for taking the time to help ..sincerely k |
| HI : In my search to put my aluminum catamaran together my this is what i have so far ...i'll use 5086 aluminum 1/4 inch for hulls and strutural areas and 3/16 everywhere else ..for the frame 6061 but i'm still not decided on the sizes and shapes to use need help here..,as far as design i intend to design it myself and build it too, even if i have no experience with boat building i'm a builder/ designer having build several houses and buildings from wood to steel and concrete and i've build some machines,trailers,and even some car and bike racing....i know this is completely diferent that's why i'm trying to get as much info about all phases of construction as possible,and i,ve found that this forum offers the best advice i apreciate having read just about everything you guys have posted .......my basic design is already on paper ,and looks like this:50 by 25 overall,two paralell hulls with the outside wall being vertical with 4 feet at water line and the inside wall openning to 6 feet on top.the bottom still not sure of shappe from a wide v to a half circle ..40 feet will be basically straight and the front 10 feet will narrow to 4 inch ....the hulls will be divided in sealable compartments and i'm not sure if i,m going to mostlly foam fill them as i don,t intend to use them but for tanks ,motors,storage......the house will go to the edjes to gain strutural integrity building it as an uncaped piramydand have 2 bedrooms ,kitchen ,bath, open area and pilot house ..the pilot house will permitt complete navigation from the inside ....windows will be all some size to easy repair and maintenance ,and door and windows will be build burglar resistant and the pilot house will be bullet proof/resistant as well....i intend to have enough motors to do 15 to 20 knotts under power and still have not decided what sistem to use ..any sugestions?..still researching rudder and dagger boards...still haven't got to mast ,sails, and navigation i intend to carry either a pw or a small fast boat in between hulls instead of a dinghy....it apears that i will buid in the u.s. even if asia is cheaper but materials and general safety still suspicious......please any help apreciated.....and if anyone is buiding aluminum in the u.s please drop me a line ..thank you ...Korvello |
| drop these guys an e-mail http://www.revolutiondesign.com.au/ the guys that run this place are all sailors and i'm sure they could help with construction. |
| From the co designer of the Silkline 510 Quote:
I am the co-designer of the Sikline 510 which has nothing in common with the Simpson cat other than they are both cats. We havent massaged the design to develop the Silkline cats. I have seen the Simpsons but have never looked at a set of plans and have never been aboard a Simpson Slipstream. You are more than welcome to come over to Thailand and view our cats in person to see for yourself. The Slipstream I saw was anchored in Southport. Only saw it from a distance from the shore. We are presently well along the line designing a 65 foot Silkline and will be introducing power versions all in alloy. Cheers Bob Mott |
| Hello Korvello, Please note I am the co-designer of the Silkline 510 cat and it is not a massaged Simpson. We have also developed CAD kits for the 510 which are available with construction plans if you are interested. I am not at all familiar with the Simpson design but have seen Slipstreams from a distance. Our underwater profiles would be nothing like the Simpson but that is a guess as I havent seen the Simpsons plans or seen it out of the water. We are due to launch a completed 510 early April and a second soon after. We launch cat 3 at sail away stage this coming weekend and begin cats 4 and 5 within the next 4 weeks. All are presold. We are developing a 65 version also in CAD. Regards Bob Quote:
| Power Aluminum CAT | vinnyt | Metal Boat Building | 4 | 05-06-2007 11:30 PM |
| Where to build 90 feet aluminum cat economically? | richardproeller | Metal Boat Building | 8 | 10-23-2006 12:55 AM |
| Aluminum CAT Designs | vinnyt | Multihulls | 0 | 10-02-2006 02:31 AM |
| Need to build a 18ft Aluminum Boat | myles king | Boatbuilding | 1 | 06-24-2005 11:20 PM |
| To build your boat/cat in Srilanka | gamage | Services & Employment | 0 | 09-03-2002 11:58 AM |
