Old 06-06-2008, 05:31 PM
lunarmys lunarmys is offline
Living on a catamaran (and building it)
Hi people
I have no experience of sailing nor any experience in boat building, but .. I have (what some might called crazy) a idea of wanting to build a catamaran and then live on it.
I'm a computer geek who work from home, so the whole plan would be to sail from shore to shore (Scandinavia -> Europe and possible down to Africa as well (and why not India?)) and work by connecting to the internet via 3G or satellite.
I would like this boat to be my permanent home.
That's the background/idea.
Are there any people out there who are currently living on a catamaran?
The plans I've seen on the net seem to be geared towards "cruise for a few days" kind of trips, whereas I (think I) would need lots of storage space for fresh water and food (I'm thinking of being out on the sea for a few weeks at a time).
Something I'm also thinking about are solar cells. Would it be possible to cover the sails in solar cells?
Any points of where I can research a project like this one? Any special keywords I could search on?
Searching for house boats give me smaller boats that don't seem to be made for the ocean, and I'd prefer a sail boat.
Any help/pointers/tips/suggestions are much appreciated!
/ d
Old 06-06-2008, 06:40 PM
chesapeake40 chesapeake40 is offline
Rep: 10 Posts: 3
Google
In a nutshell, a catamaran of the size and outfit that you may require could take thousands of hours to build by yourself (4000-8000 is a rough guess assuming you're somewhat handy), and could cost you hundreds of thousand of euros.
Assuming your goal is seen to completion, my initial thought is that a catamaran is not just a floating house. You may be underestimating the costs (time and money) associated with maintaining and sailing a boat in this manner (long term cruising with all the gadgets). It can be nearly a full time job in itself.
I'd start with some googling of everythign that comes to your mind on the subject ("catamaran circumnavigation" or "living on a catamaran" seem to have promise) . All of your questions so far can more easily (and more thoroughly?) be answered by sources already written and available online. Solar panels, watermakers, fuel cells, satellite links...it's all out there for better or worse...
For some info on the lifestyle awaiting you, a search on Amazon for "Sailing" or "Crusing" will yield a few standout books ("Voyager's Handbook" is one that comes to mind).
Good luck!
Old 06-07-2008, 01:36 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 513 Posts: 940
Lunarmys, I reckon thats a fantastic scheme for you which I have done myself but not cruised as extensively as your envisioning, however a better course of action for you could be to buy a suitable vessel & live aboard much sooner saving on building effort & building premises etc in the mean time, as Chesapeak40 has already represented theres 3-4 man years involved in building a cruising vessel to live aboard comfortably, where as you could spend that time saving on rent etc & further outfitting the vessel & training for the adventures & fun ahead. All the best in your plans from Jeff.
PS: or you could start your adventures in Australia after buying a boat here.
Old 06-07-2008, 03:04 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
There is a Wharram Catamaran site
http://www.wharram.com/links.htm
that may be helpfull. He is big into the 'self sufficient sailor' concept, and many of his designs are nice and simple, for simple living.
If you are single, building as you sail might work.
I dont think sail of solar cells are viable yet, but who knows in the future
Old 06-09-2008, 06:36 AM
northerncat northerncat is offline
Rep: 9 Posts: 170
if your prepared to invest around 100000 and 2000hrs of time you can build ply bridgdeck cats about 40ft long that would fill your needs
sean
Old 06-09-2008, 09:07 AM
rwatson's Avatar
sean
Lets see - between 100000 and 2000 hrs - thats a range of 34 to 2/3 working years assuming an eight hour day, 7 days a week!
Did you mean 1000 hours or 10,000 hrs ? :-)
Fun aside, whose plans were you thinking of? The Wharram site (no bridgedeck) estimates 4000 hours for a forty footer, and 2200 hours for a 38 footer, and they are quite 'simple' boats, built with fairly old methods, so modern designs should be able to imporve on that I would have thought.
Check out www.gleda.org/welcome/ for an insight to building a plywood cat. it looks like you will spend 1000 hrs on this 38 footer just to get her afloat, let alone live while building. and the dust ........ and sanding ..... and epoxy smell ......
Old 06-09-2008, 02:40 PM
Manie B's Avatar
Manie B Manie B is offline
Rep: 1391 Posts: 1,539
i have never really understood the attraction of a wharram design, open deck and deep "v" hulls, is it still an old hippie thing? smoking grass under the stars?
my favourits have always been "easy" or "woods" or "lavranos" and lets get serious nothing else really compares, schionning and kelsall are not in the same financial league for home builders
lunarmys you have got some very serious homework to do. but dont stop, keep on the reading and research, it is a wonderfull journey that will keep you going for the rest of your life
Old 06-10-2008, 06:25 AM
rwatson's Avatar
yes - all the wharram cats I have seen appeared really lacking for decent accomodation. I have never done price comparisions, but surely better use could be made of all the material in those slab sided V hulls.
I notice that the "old" kelsall designs are being sold still. These plywood designs actually are good value, in that they use major elements of his 'fast building' techniques, and you end up with a much more spacious craft.
I would put those designs at the top of the likely lists if building speed was a big issue (and when isnt it?)
Old 06-10-2008, 07:57 AM
Rep: 9 Posts: 170
sorry i meant 100000 dollars aus and 2000 man hours
sean
Building a Catamaran - Costs? Friday Boatbuilding 46 03-30-2009 09:12 PM
Benifits of Living Aboard timgoz Open Discussion: All Things Boats & Boating 40 09-07-2007 05:59 PM
building boats for a living??? dkopchak Powerboats 20 11-19-2006 11:44 AM
catamaran building schools? kagmur16 Boatbuilding 11 02-20-2006 08:03 AM
Building a catamaran passy Boatbuilding 3 08-29-2005 05:11 PM
