Old 10-04-2003, 08:55 PM
turnershells turnershells is offline
Rep: 10 Posts: 22
Liquid Ring Vacuum Pumps?
Anyone have experience rebuilding one of these?
I've been using a 3hp refridgeration compressor which doesn't really want to go over 21inHg but apparently the liquid ring pumps working with oil will pull 29inHg pretty easily.
The rebuilding part comes because I bought a 5hp liquid ring pump several years ago, third hand, mostly for the tank and the motor controls. Some bright spark put the whole thing into storage with about three inches of water in the pump, and I've just taken it apart to survey the damage.
It looks like a fairly straight-forward job to machine the four plates that face against the two impellors. The rings around the impellors will also need to be machined, and re-lined to match the impellors. The rest of the rust I can take off with my die grinder and scotch-brite pads.
Questions is: how tight do the tolerances have to be? I'm going to get a local shop to do the machining and do everything else myself, but I don't want to get everything back together and find it's too tight to turn or too loose to pull a good vacuum. My inclination is to go with a standard turned finish on the lathe without any further work.
Any help would be appreciated.
Regards,
Matt Turner
Turner Racing Shells Ltd.
"Buying tools I don't need with money I don't have."
Old 10-22-2003, 08:32 PM
Ed Harrow Ed Harrow is offline
Rep: 10 Posts: 16
Matt, I spent nearly 20 years in vacuum technology, but never ran across one of these, tho I am aware of them. Believe it or not, water is quite commonly used as their working fluid, but if lower ultimate pressures are needed, a suitable vacuum pump oil would be used in place of water.
I'm attempting to contact various parties to see if I can further assist. So far no one has been able to help me with respect to your question. One question that has already come up - what is it? Who made it? Single or dual stage? Do you have the model number?
No promises here, but I'll see what I can uncover.
"There is some soul of goodness in things evil,
Would men observingly distill it out."
Old 11-13-2003, 08:00 PM
Rep: 10 Posts: 16
Matt, I'm sorry that this took so long... I haven't really found out anything earth shattering. He whom I felt would be your best hope also ain't laid eyes on one.
Best guess: Clean up the bits, put it together, and see what happens. His best guess is that tolerances can't be all that significant.
I'm going to keep poking to see what else I can find out for you.
Old 12-09-2003, 10:37 PM
aguest aguest is offline
Rep: 10 Posts: 13
I have been trying to learn all I can on vaccum bagging? I've got the basics but can anybody go into detail? Thanks - Ricki
Old 12-12-2003, 07:31 PM
It sounds like you have a flat sided 2 stage pump, the clearances should be about .005-.007 per side. You can contact us at www.liquid-ring.net tour our site and if we can help, give us a call
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 05:00 PM
Option One - how big Willallison Option One 43 12-20-2005 06:44 AM
vacuum bagging or vacuum infusion Eisa Hasan Fiberglass and Composite Boat Building 10 03-29-2005 04:25 PM
Vacuum Pumps. War Whoop Marketplace 0 07-14-2004 11:17 PM
vacuum pumps rogerbergo Materials 17 02-25-2004 05:04 AM
