Old 02-11-2012, 12:54 AM
zptaiopdhnfcre zptaiopdhnfcre is offline
Rep: 10 Posts: 9
lbs per sq. ft.
i once knew this question;
how many lbs. does it take to sink 1 sq. ft. 1 inch ?
thank you !
Old 02-11-2012, 02:10 AM
dougfrolich dougfrolich is offline
Rep: 178 Posts: 567
Sink it into what?
If you take an ave. seawater density of 64lbs./ft^3 then it would take 5.33 lbs.
Old 02-11-2012, 06:59 PM
Rep: 10 Posts: 9
whoops............!
sorry !
i take it it must be a different number# of calculation for fresh water and salt water ?
are the numbers of lbs. different ?
Old 02-11-2012, 07:14 PM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
Originally Posted by zptaiopdhnfcre View Post
whoops............!
sorry !
Yes. Salt water is denser, so it takes more weight to displace it. Whether that's significant or not depends a lot on what you're playing with... you may not even notice it with a canoe, for example. But a cargo ship has separate Plimsoll lines to indicate its maximum load capacity in fresh water and seawater, among other variables.
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
Old 02-11-2012, 07:34 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,849
thank you !
What is the question, how much to sink a sq inch or a sq foot?
If you once knew the answer you would think you would know the question.
Old 02-11-2012, 09:41 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Archimedes principle. Buoyancy of a floating object equals the weight of the volume of water displaced. A volume of 1 sqare foot x 1 inch is 1/12 of a cubic foot. Sea water weighs approximately 64 lbs per cubic foot. Fresh water weighs approximately 62.4 lbs per cubic foot.
David Cockey
Old 02-12-2012, 12:30 AM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
when will the Americans learn that metric is the way that makes the world tick...?
What is simpler than 1 liter of water = 1 kilogram. One cubic metre (1000 lt) = 1000kg For decimals - just move the point.
Wynand
A scatterling of Africa
Old 02-12-2012, 04:01 AM
lewisboats's Avatar
lewisboats lewisboats is online now
Obsessed Member
Rep: 1263 Posts: 1,840
Our foreheads are thick and our brains are small...maybe we'll catch on by the time we step foot on Mars.
Steve Lewis
Lewisboatworks
http://angelfire.com/ego/lewisboatworks
Old 02-12-2012, 08:01 AM
rberrey rberrey is offline
Rep: 69 Posts: 287
It,s like a railroad track and a Roman road , if it,s not broke dont fix it.
Old 02-12-2012, 11:00 AM
Engineer
Only if fresh water. Density of salt water is not a nice, round number in the metric system.
David Cockey
Old 02-12-2012, 01:39 PM
Wynand N's Avatar
Salt water: SG = 1025kg per cubic meter
1 liter = 1.025kg and one cubic meter (1000lt) = 1025kg
Because meter cube it is a thousand liter units (three zeros), the decimal get moved 3 places, simple as that...
Wynand
Old 02-12-2012, 05:52 PM
tinhorn's Avatar
tinhorn tinhorn is offline
Rep: 272 Posts: 552
Now you're just showing off.
Old 02-12-2012, 06:37 PM
Rep: 10 Posts: 9
thanks
hey thanks for all the info !
you people really try to help.
thanks.
Old 02-12-2012, 06:50 PM
SheetWise's Avatar
SheetWise SheetWise is offline
All Beach -- No Water.
Rep: 574 Posts: 274
Well ... I believe it was Jimmy Carter who mandated the conversion ... and we did actually see some providers of petrol convert to liters ... but that was just to disguise price changes ...
You're right of course. We're very obstinate. On the other hand, we're also very talented ... we can use both
Time is Gods way to keep everything from happening at once.
Old 02-12-2012, 06:57 PM
Rep: 10 Posts: 9
does anyone need a fiberglass laminator or a mold maker ?
how many lbs of thrust is equal to 1 hp? deermaster Outboards 72 12-15-2010 04:34 PM
Area needed to support 300 lbs 360weatherbound Boat Design 16 03-02-2010 04:39 PM
lbs. per sq. ft. guest200901 Boatbuilding 9 07-26-2007 07:55 PM
