Old 03-02-2006, 09:33 PM
wdnboatbuilder's Avatar
wdnboatbuilder wdnboatbuilder is offline
Rep: 15 Posts: 227
Laminating Plywood
Cold mold build, every thing being the same, which would be stronger better to laminate 4 pieces of 1/8" ply equaling 1/2" or would it be stronger to laminate 2 pieces of 1/4"?
I understand that the 1/4 and the 1/8 would have to be able to bend the same radius.
The point of the question is that I'm trying to save weight although the wood is close the weight saving would come in the glue joint where you would only have one joint in the 1/4" than the 3 joints you get with the 1/8". It could be that it ends up the same but just looking for and value your comments.
Thanks
Calm days, Tides Running, and Fish Biting
What more could you ask for?
Bruce
Old 03-03-2006, 05:35 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
1/8'' (3mm) is normally 3 plies, while 1/4'' (6mm) is 5 plies.
This means you have a more balanced laminate with the 1/4'', with 40% in one direction and 60% in the other.
With many layers of 1/8'' you can decide in which direction you want to have most of the fibres, with fewer layers of 1/4'' you will have almost the same strength in every direction.
Of course you save some glue (weight, work and money) with fewer layers.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Laminating BLueOne Materials 4 04-19-2005 08:52 PM
vacuum infusion laminating HWL Fiberglass and Composite Boat Building 40 03-28-2005 02:38 PM
laminating on new glass BLueOne Fiberglass and Composite Boat Building 6 03-09-2005 03:17 PM
Jig for laminating frames? Mohan Pakkurti Wooden Boat Building and Restoration 8 02-10-2005 07:22 PM
Epoxy Laminating Resin JEM Fiberglass and Composite Boat Building 0 11-17-2004 09:45 AM
