| which kind of plywood is good for a canoe hi guys help which kind of plywood is good for a canoe and How thick should a deck usually be and also for the right side and left side in canoe? I will wait your answer thanks |
| You have another thread with the same questions. The answer is always: depends on the design. At the very least post a set of lines of the canoe you plan to build.
__________________ Gonzo |
| Yaasaay, you can't design a canoe. This isn't a personal dig at you, but just an observation of your previous questions, interests and general knowledge. The only plywood to truly consider for a canoe is Okoume. The reason is simple, weight, which is a huge design consideration, especially with a canoe or any small craft. If you want to build a canoe, may I suggest the "Quick Canoe" by Michael Storer. You could build it in a weekend or two, the engineering already done for you and the plans will tell you what size and type of plywood to use. http://www.duckworksbbs.com/plans/st...c150/index.htm ![]() |
| Could a plywood coated with epoxy canoe be used as a mold? | yoram | Boat Design | 26 | 05-15-2011 08:21 AM |
| Luanan Plywood-good or bad? | holly | Multihulls | 7 | 08-19-2007 09:39 PM |
| plywood- good source in scandinavia? | Bobbelurman | Materials | 0 | 05-21-2007 01:41 PM |
| Thickness of Plywood for a canoe. | Panos_na | Boatbuilding | 5 | 06-21-2005 06:45 AM |
| Glass over good plywood hull? | Ed Hoban | Wooden Boat Building and Restoration | 10 | 02-11-2005 12:26 AM |
