Old 05-01-2011, 06:00 AM
CatBuilder CatBuilder is offline
Rep: 1320 Posts: 3,040
Keel Laminations - Revisited
How do you guys normally do your internal keel lamination on builds that come together like these pictures?
See this photo for an example:
In that photo, how are the keel laminations done under those bulkheads that are already in place??
Also, here is another photo. They have the full, permanet bulkheads in the first hull half and will join it with the second half on the mold:
How are those people possibly dong the inside keel laminations after one hull joins the other?
There are a couple of problems:
1) If I put the keel lamination together before putting bulkheads in, I cannot use permanent bulkheads when moving the first hull half out of the mold.
2) If I put the bulkheads in first, I can't get hull-length pieces of biaxial cloth *under* the bulkheads to do the lamination.
This problem has been talked about before, but not 100% resolved.
What is the best way to do this? How does everyone else do it?
Thanks!
"You can't solve all of life's problems with epoxy" - My Wife
Running laminations through thicknesser? Corley Wooden Boat Building and Restoration 8 02-12-2010 12:36 AM
PVC Structure and Laminations JCFARER Materials 43 11-20-2009 07:57 AM
help with verticle laminations / foam core pescaloco Fiberglass and Composite Boat Building 31 11-05-2007 11:07 PM
# of laminations? Broknangel Powerboats 1 04-23-2007 06:17 PM
pollution reduction on fiberglass boatbuilding and laminations surmeli Materials 4 12-27-2005 08:39 AM
