| Kayak seats I'm getting ready to fit out the cockpit on the Raptor and trying to figure out what to do for a seat. I'm looking at the seats they sell for sit-on-top boats but they're ridiculously expensive and not really optimized for a sit-inside boat. What have other people done for seating in their boats?
__________________ Aluminum welding is like sex. The first few times you had at it, you probably could barely please yourself, but with practice and some guidance, you managed to impress one or two prom dates. ~PAR |
| You want to get that right, it makes a big difference to the sitting pleasure. I have to consider the same thing myself, and I havnt found any 'off the shelf' seats that I thought were comfortable and well priced either. At the moment, I am planning to carve a quality bum shape in some closed cell foam, and cover it with epoxy/glass. Then, I will glue some Velcro strips to the top of the fibreglass, and get a soft rubber block about an inch thick to sit on top, held down with the Velcro. My thought was to anchor the fibreglass seat by gluing some nylon 'ribbon' to the bottom of the boat, both sides of the seat, and lacing the seat down with 'string'. Any other ideas would be of interest to me too. I was thinking that foam would help with flotation if the cockpit got flooded too. I |
| Find a plastic chair that fits you well and cut the seat off.
__________________ Gonzo |
| If I where going to build my own kayak I would put a lot of effort in making or getting the right seat that fits me. If I would make it myself, I would do it this way: Get bean bag chair and cover it with thin plastic. Find out from sitting in your kayak what angle would be most comfortable between your back and legs. Take measurement from your knee to chest. Make a template out of thin plastic of approx. measurements of the seat you want and add about 3 inches in each direction. put the template on the bean bag and try it out by sitting on it to see where to aim your behind to get it in the right location under you. Use the template to cut 600gr strand mat. Wet the strand mat on the template with resin, 3% catalyst. Roll the air out. Place the strand mat on the bean bag with the template under it. Put thin plastic over the wet mat. Sit on the mat on the bean bag with the added layers of clothing you would use on your kayak. Push yourself in and measure the distance from your knee to your chest and sit still for about 40 minutes and then carefully stand up. wait another 30-60 minutes and peel the plastic of the shell and trim it to desired shape with knife or scissors. The shell will have a lot of wrinkles in it and you can either build it up with more layers of fiberglass or use it to make mold for new seat. Axel |
| Thats a great idea IB. I was wondering how to get the contours right - bean bags are a great concept. Getting out carefully, and not disturbing the beans while laying resin are the key. I might prefer to use the bum shape as a template for taking off dimensions for the carving. Gonzos concept of taking all the hard work out with a premade plastic seat also appeals greatly. You could also get a back shape from it if you cut down the back of the chair and mounted it properly with the seat. The big 'if' is getting a plastic chair that suits a paddling position. Hours of paddling sitting on some of those general purpose plastic seats could be daunting. |
And you would need to sit in it until the fiberglass hardens some. It is very hard to stand up from bean bag chair without disturbing it. |
| I decided to try to make the seat according to my description in post number 4. When I have paddled kayaks for long distances, the only discomfort is from the seat not fitting to my bottom, resulting in loss of blood flow to my legs and not being able to brace myself comfortably with my knees against the deck when I need to paddle hard. I did everything according to the description, but I would suggest using less catalyst. It got very hot sitting in the seat where resin accumulated and it took only 10 minutes to harden so I could stand up. The chain hoist helped me to stand up without disturbing the bean chair. The seat is now ready to be trimmed to desired shape, faired and panted to make a mold or build up with more layers of fiberglass and use as a seat. Axel |
| The easiest way to make a seat is to get some EVA foam and carve it out with first a bread knife, and than a Sureform file (looks like a fine cheese grater). It is fairly fast, and it makes a comfortable seat, that also adds bouancy to the kayak. You cut the lower side to match your kayak hull, and carve away the "seat" side to match your backside (with many "test fits" as you shape it). Large blocks of EVA foam are pretty costly, I like to find scraps and glue them together and carve the seat out of something approximately the shape I need. See this web site: http://www.redfishkayak.com/seats.htm Redfish also sells seat "blanks" that are already roughed out, or completed seats if you want to pay for all the hand labor to make one. If you come down my way sometime soon you can have as many EVA scraps as you want, I have several boxes of scraps I got from redfish kayaks. |
| The EVA "minicell" seat blanks are actually not that costly, I just looked them up. See it here: http://www.redfishkayak.com/foam.htm |
| If anyone is following this thread, I bought a junker life jacket for $10 and sliced it up which gave me enough closed cell foam for a comfortable seat. Pics to follow.
| might be good to research how they construct and mold a race car seat to the driver. Several videos... http://www.youtube.com/watch?v=whGgOQOD0ZU |
| Anyone have experience bonding closed cell foam to itself and other things? Is there something that will stay at least a little flexible when dry and not eat the foam?
| Sikaflex would be a good candidate. You may also like to drop in to your local specialised craft centre, and check out their range of 'goos' I remember buying a mixture used for flexible moulds that was very robust, tough and ... flexible. They are fairly expensive, but you would only need a shallow layer to provide that bit if 'give'. Something like that is on my 'to do' list. |
| foam in seats | 14ft | Stability | 1 | 04-05-2011 07:24 PM |
| Kennedy Kraft 14ft - bench seats to pedestal seats is it worth it??? | ChicagoPete | Boat Design | 4 | 03-22-2009 12:53 PM |
| Srength in the seats | philzero44 | Metal Boat Building | 2 | 03-25-2008 11:08 AM |
| project with seats | ranMan | Boatbuilding | 3 | 01-21-2007 10:06 AM |
| interior seats | roadking666 | Materials | 0 | 10-28-2006 08:13 AM |
