Old 12-11-2009, 04:26 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,591
Inside Out
I'm considering building an experimental 15' sailboat of my own design in a way that is unique to me. I've built over twenty boats -most by building a plug then a mold. This would be one of only three one offs I've built using plywood.
Whats different about this is that I'll build a strong back and set up frames that will touch the outside of the skin. The boat uses tumblehome from the bow to stern so the frames outline the shape of the deck, cockpit and sides.
In order to be able to glass the inside of the 1/8" ply skin I need to be able to hold the skin to the frames so that nothing intrudes on the inside. I've considered "tacking" the skin to the frame with glass but that will leave numerous areas on the outside to fix when the boat is pulled off the frame/strongback. The ply will be glassed(carboned) and reinforced and the bottom installed before removing the boat from the frame.
Any suggestions as to how to hold the skin to the strongback/frame while the inside of the boat is completed without creating a nightmare of finish work on the outside of the skin-or interfering with the inside glassing?
yes, it is a revolution
Old 12-11-2009, 05:20 PM
Itchy&Scratchy's Avatar
Itchy&Scratchy Itchy&Scratchy is offline
Rep: 117 Posts: 141
A decent industrial glue gun??
J
Im working on my second million.........I gave up on the first!
Old 12-11-2009, 05:24 PM
Rep: 117 Posts: 141
If you use long panelpins ie: Nails with very small heads, you could pin the ply to the frames and afterwoods you should be able to pull the frames off and then use nail pliers to pull the pins out/through the ply, if you know what I mean.
Or use brass pins and then just snip them off and leave the remainder in the ply.
J
Old 12-11-2009, 05:32 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
Try hot melt glue. Scrape it off after glassing the inside. It won't hold very well but should hold well enough. Test it first, though, before trying it on the real thing.
Hoyt
Old 12-11-2009, 05:38 PM
boat fan's Avatar
boat fan boat fan is offline
Rep: 357 Posts: 681
Difficult to do without leaving at least some small holes in the skin.
One possibility would be to use heavy fishing line.
1 . Dill the smallest holes possible to allow the fishing line to go through the panel.
2 . Push panel to contact frame and tie off at the external frames , glass the interior and snip off the line when done.
3 . Fill the holes.
The trick would be to minimize the number of fixings or holes.If you use single line with a simple knot on the inside you may not need to repair too much.
How big a reproduction are you thinking and do you have crew and money dripping off your butt?( PAR2009)
Old 12-11-2009, 05:48 PM
hoytedow's Avatar
Resistor
Epoxy glue wood cleats to outside of skin which you can fasten to to pull skin to basket. After inside has been glassed, sand off cleats.
Hoyt
Old 12-11-2009, 06:02 PM
Doug Lord's Avatar
Flight Ready
Thanks for the ideas, guys! I had considered gluing wood blocks to the skin then screwing the block to the frame. My first thought was to cut something like 1X2 blocks but grinding a bunch of those off the outside skin would be tough without damaging the skin. Just now I thought of using balsa blocks that would grind off a lot easier.
But there must be a better way. I haven't ruled anything out or in and your continued help is most appreciated!
Old 12-11-2009, 06:08 PM
boat fan's Avatar
Rep: 357 Posts: 681
How thick are the ply panels , doug ?
Old 12-11-2009, 06:19 PM
Doug Lord's Avatar
Flight Ready
.125"(1/8th) Okoume (from Boulter) to be carboned inside and out.....
Old 12-11-2009, 06:20 PM
wardd wardd is offline
Rep: 443 Posts: 925
how about fiberglass tabs epoxied on the hull to frame
1"x1"x1" should do
cut the tabs off sand a bit and glass over
Old 12-11-2009, 06:34 PM
boat fan's Avatar
Rep: 357 Posts: 681
1"x1"x1" should do
Sounds feasible actually.....
Old 12-11-2009, 06:35 PM
hoytedow's Avatar
Resistor
Yes, wardd has the best idea.
Hoyt
Old 12-11-2009, 07:03 PM
Doug Lord's Avatar
Flight Ready
1"x1"x1" should do
Thanks! It's sure worth a test. My experience(limited) grinding anything epoxied to thin plywood is not good-but I'll give it a shot.
Old 12-11-2009, 08:45 PM
Doug Lord's Avatar
Flight Ready
You guys have been great and I appreciate it a lot. I've got this kind of wild idea-see what you think:
1) use plastic staples to staple skin to the frame.
2) grind small recesses in the frames at the locations where the staple will be put in, the idea is that when the skin is up against the frame a portion of the
staple will be visible,and more importantly, accessible.
3) when ready to pull boat off frame a small chisel would be used to cut the plastic staple.
What do you think?
Old 12-11-2009, 09:55 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,580
Straps on the outside, I have never tried it with ply but have built a stripper that way. Once the inside is glassed you can remove them and finish the outside.
Gary
http://www.mfrexpress.com/1x12-heavy...l?currency=USD
"The hand feeds the mind."
Weston Farmer
Replacing the core from the inside. Mike2444 Boatbuilding 16 11-15-2009 09:40 PM
I want my turnbuckles inside the boat! Omeron Sailboats 3 06-28-2007 07:10 AM
acrylic for inside cabin mattoc Materials 3 06-05-2006 07:26 AM
new way to light up the inside of your boat Packeteer Boat Design 14 08-13-2005 11:03 AM
epoxy and glass inside and outside? and more Nordson1960 Wooden Boat Building and Restoration 6 05-22-2005 08:26 PM
