__________________ How big a reproduction are you thinking and do you have crew and money dripping off your butt?( PAR2009) |
| You can glue flathead screws with epoxy to ply.. release with heat (DC source?) and scrape the rest of the epoxy while it's still warm.. |
| how bout that glue that they use to temp used to seal junk mail, that peels off in a strip? or try rubber cement |
| You don't need the small recesses. Plastic is fine but not necessary. I think that you would be happiest with ItchyandScratchy's idea of panelpins (why wouldn't this automatically come to mind?). My vote is to not use epoxy as it is much harder than the ply and will be a bugger to get off. Ask for Joubert ply from Boulter. It has a fungicidal glue and won't easily promote rot. If you use hot glue, get the strongest, 3M, you can get. Splash a little denatured alcohol to remove. Really, try this - you will be amazed at how something that sticks that well can be removed that easily. |
| inside out Quote:
Boulter doesn't list Joubert-any other sources you can think of? edit: found several sources-its interesting that at least two companies claim to be the "exclusive supplier of Joubert plywood" in the US... -------- Thanks for the ideas guys-I'll test several of them....
| Joubert Suppliers Here is a fairly comprehensive list of Joubert marine plywood distributors in the US (From WoodenBoat advert): >Almquist Lumber, CA 707-825-8880 > > Atlantic Plywood, MA, NY, ME, CT 800-937-6700 > > Condon Lumber, NY 914-946-4111 > > Connecticut Plywood, 860-953-0060 > > Cross Cut Hardwoods, OR 503-224-9663 > > Chesapeake Light Craft, MD - 410-267-0137 > > E-boat - FL, 772-770-1225 > > Edensaw Woods, WA 360-385-7878 > > Forest Plywood, CA 800-660-9369 > > Frost Hardwood, CA 858-455-9060 > > Homestead Hardwoods, OH 419-684-9582 > > Houston Hardwoods, TX 800-606-6176 > > LL Johnson Lumber, MI 800-292-5937 > > MacBeath Hardwoods, CA 510-843-4390 > > MacBeath Hardwoods, UT 800-225-3743 > > McEwen Lumber, NC 800-662-7468 > > Plywood & Door, IL 866-738-7224 > > Riverside Lumber, LA, 800-669-6624 > > Roberts Plywood, NY 631-586-7700 > > Russell Plywood, DE 800-787-7355 > > Seafarer Marine, FL 954-763-4263 > > West Wind Hardwoods, BC 800-667-2275 > > Whittelsey Wood, FL 305-621-4242 > |
| Thanks for the list!
| Replacing the core from the inside. | Mike2444 | Boatbuilding | 16 | 11-15-2009 09:40 PM |
| I want my turnbuckles inside the boat! | Omeron | Sailboats | 3 | 06-28-2007 07:10 AM |
| acrylic for inside cabin | mattoc | Materials | 3 | 06-05-2006 07:26 AM |
| new way to light up the inside of your boat | Packeteer | Boat Design | 14 | 08-13-2005 11:03 AM |
| epoxy and glass inside and outside? and more | Nordson1960 | Wooden Boat Building and Restoration | 6 | 05-22-2005 08:26 PM |
