Old 09-24-2004, 12:08 AM
Hypercat Hypercat is offline
Rep: 10 Posts: 10
Inboard shaft question....
On boats with inboard engines, where is the thrust produced by the prop directed to? The gearbox? a thrustbearing located somewhere on the shaft? the stern bearing? Excuse my ignorance but I cant find an example of one anywhere. I'm refering to smaller 15-25 ft ski boats & not I/O's Thanks.
Old 09-25-2004, 09:53 AM
Eric Sponberg's Avatar
Rep: 2464 Posts: 1,381
Without any thrust bearings, the thrust from the propeller shaft goes directly into the gearbox, the engine, and the engine mounts, then to the hull structure. With a thrust bearing, the bearing is hardmounted into the boat between the stern tube and the gearbox. All the load then goes to the thrust bearing and the boat structure. There is then no thrust load between the thrust bearing and the gearbox/engine. Therefore, with a thrust bearing, the engine and gearbox can be mounted on softer mounts, thereby reducing structure-borne vibration.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
New question prop selection simso Propulsion 0 09-01-2005 05:47 AM
short shaft motor on long shaft boat ohenry Boat Design 0 03-21-2005 09:02 PM
I/O to Inboard Conversion; DWL Question MDuff Powerboats 7 11-23-2004 05:04 AM
Propeller shaft bearings, whirling vibration christos Powerboats 3 05-08-2004 08:42 PM
Keyed to Splined Propeler Shaft CaptPPan Powerboats 1 03-15-2004 09:38 AM
