Old 05-29-2005, 10:14 AM
Corpus Skipper's Avatar
Corpus Skipper Corpus Skipper is offline
Hopeless Boataholic
Rep: 173 Posts: 604
Go out and buy a reconditioned 350 G M marine engine with trans. complete @ a discount price. Do the same for a auto recondition engine and marine trans. Then price out used marine parts to convert the auto to a marine. Post the $$ and where you can get all the parts. You will be almost as old as me and the engine will be as reliable as my reconditioned body.
O.K.
2 1980 Crusader 270 rebuilds (Chevy 350), 1 block was no good, no good heads (raw water cooled).
1 1969 4 bolt main 350 block standard bore (came out of my old truck)- free (sorta)
1 new forged crank $589.00
2 sets Summit Stage II connecting rods $699.70
2 sets Sealed Power competition main bearings $93.90
2 sets same brand rod bearings $104.78
2 sets same brand cam bearings $31.90
2 sets Keith Black hypereutectic pistons, flat top .030 over $346.78
2 sets Sealed Power plasma moly rings .030 over $200.00
2 Felpro gasket sets $64.00
1 Comp Cams roller timing set $49.95
2 Melling High volume oil pumps w/ driveshafts/ sleeves $77.52
1 reverse rotation camshaft (the only "marine" part inside the engines) $169.00
1 set Rhodes hydraulic lifters $99.95
1 Comp Cams camshaft w/ lifters with same lift, duration, and lobe separation as reverse cam $96.95
Machine work: both bored .030, decked, align bored, honed with torque plates, cam bearings installed, pistons hung, 1 crank turned .010/.010, all balanced $1,500.00
2 pair of reworked heads 1.94/1.60 SS valves 3 angle grind, new springs, keepers, retainers $400
2 sets Osco Crusader replacement manifolds, risers, elbows $900.00
2 fresh water cooling kits $900.00
2 marine starters rebuilt $120.00
2 marine alternators rebuilt $150.00
2 carburetor rebuild kits $65.00
My labor, priceless!!!
Grand total $5758.43
1 new Crusader 330 5.7 around $7,000.00
All parts from Summit Racing except for reverse rotation cam from Marineparts.com, manifolds from small co. in PA (can't find reciept, but found them online easily enough) Same for FWC kits. Starters and alternators rebuilt courtesy of Corpus Christi Battery. Many thanks to Roger's Precision Machine for the fine machine work, and Harbor Engine and Grinding for the heads. Trannys only got a new coat of paint and an oil change because hey, Velvet Drives last forever!
Craig Cavanaugh
Silver King Custom Marine
No shoes, no shirt, no problem!
Old 05-29-2005, 10:19 AM
Hopeless Boataholic
Rep: 173 Posts: 604
Oh, BTW, they're reliable as H#@!! (now if I could just afford those Holley marine EFI systems.)
Craig Cavanaugh
Old 05-29-2005, 10:20 AM
Hopeless Boataholic
Rep: 173 Posts: 604
Oh, yeah, I/O for fresh water or trailered boat, V drive if she sets in the brine.
Craig Cavanaugh
Jet Drive Jet Drives 15 12-18-2006 09:51 AM
drive options; vee, stern, jet curtis73 Powerboats 5 08-07-2005 08:29 PM
25 Vee and 41 Cat Molds maxthunder Boat Molds 5 12-15-2004 10:19 PM
converting I/O to V-drive captainstogie Powerboats 3 08-09-2004 10:39 AM
O/B or I/O -- Which to purchase? wazzu98 Powerboats 2 09-06-2002 01:44 AM
