Old 09-06-2007, 11:15 AM
justinDesign justinDesign is offline
Rep: 10 Posts: 29
Hull design question (for thesis project, please help)
I am designing a 14-16 ft inland fishing vessel and am looking for hull type suggestions. The criteria is that the vessel must have low draft, be easily planed, and remain stable while at rest, due to the fact that one is intended to stand up and fish in it.
Any suggestions, pictures, or websites would be helpful.
Old 09-06-2007, 03:51 PM
Trevlyns Trevlyns is offline
Senior Citizen/Member
Rep: 461 Posts: 689
This may be off the mark, but gives a bit of food for thought
Click here
Best
Trev F – Amateur designer and part-time layabout.
Old 10-26-2007, 03:44 AM
thudpucker's Avatar
thudpucker thudpucker is offline
Rep: 330 Posts: 703
You make me feel tired emotionally.
Your gonna try and write a thesis on something about as common as dirt?
Theres photos, designs and brochures all over the net.
But you need to say what feature your design has, not what another guy's has.
And then explain it in terms of Physics.
And then proove that your design will do what you think it will do.
And then make sure you do the same with ever aspect of the hull, all the while making certain that each aspect will be compatible with each other aspect.
And then do it all over again when you discover that one aspect will counteract another and you made a comprimise.
Then you have to go over the whole thing again, and again....until it's all compatible and will work together as a system.
Lordy, I've gotta lay my head down an cry for a bit now!
Be sure to post a picture or drawings of your tentative ideas.
HELP with thesis project justinDesign Boat Design 2 08-31-2007 03:05 PM
Go easy on me, Newbie here...Concave Hull design question... j. h. weil Boat Design 8 12-15-2006 12:13 AM
hull design question. luisjg Fiberglass and Composite Boat Building 3 04-28-2006 10:53 PM
Hull Design Project BWJF Boat Design 2 03-05-2005 04:27 PM
Need LASER 1 3D model for my thesis Tomas atria Boat Design 0 02-06-2004 01:43 PM
