Old 02-24-2008, 11:48 AM
elioti elioti is offline
Rep: 10 Posts: 21
How thick csm for my cabin?
Hi there, i,m extending the cabin on my 34ft motorboat, how many layers of 450g csm should i use, need to walk on the top on it after! Cheers
Old 02-24-2008, 02:06 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
Without any warranties: Knees and bended beams, Marine grade plywood and 450g one layer, Marine paint on top. Sole GFP is way too heavy...
Old 02-24-2008, 02:16 PM
Rep: 10 Posts: 21
Its was originally done in grp, is there such a weight issue? Thanks for reply
Old 02-24-2008, 02:27 PM
TeddyDiver's Avatar
Gollywobbler
It's allready a quite high cabin so any additional weight high on the boat is.... at least unpleasant, and in the worst case dangerous. DIY laminations tend also to be less rigid and heavier. Anyways it's also easier done with ply and GRP cause no mold is needed..
Old 02-26-2008, 05:17 PM
Rep: 10 Posts: 21
Thanks Teddy, well have already started laying over ply, have done three layers already, was planning on taking the ply out afterwards, do not think the boat will be top heavy, is a heavy lay up and the engine that may go in weighs over a ton, not sure what to think now..
Old 02-27-2008, 04:30 AM
TeddyDiver's Avatar
Gollywobbler
Ok! it will work, except every ounch is out of loading capacity...
How thick should my cabin bulkheads be?? mongo75 Fiberglass and Composite Boat Building 19 04-08-2008 07:05 PM
CSM and roving Bluedesign Boat Design 1 05-21-2007 05:37 AM
CSM Veil Bullseye Fiberglass and Composite Boat Building 4 10-18-2006 07:11 PM
CSM/WR vs Stitched Bx/Qx MattStudent Fiberglass and Composite Boat Building 2 04-20-2006 10:50 AM
18-24' Cabin / Half cabin moulds Louis Boat Molds 0 07-27-2005 04:48 AM
