| How much fiberglass over plywood? I'm replacing the plywood decks, cabin top and sides on the boat I'm restoring. How many layers and what thickness of glass to use? I thought I'd use System Three but read in this forum about the US Composites epoxy being alot cheaper. Any opinions? Dan |
| All of the major formulators of epoxy offer products with similar physical properties so use the goo you're comfortable with. On a deck that doesn't need the additional support of 'glass and is strong enough without it, the fabric serves as abrasion protection. In this case you don't need a lot. Typically 8 ounce fabric is fine, though a little thin for high traffic areas or workboats. Two layers of 6 or 8 ounce can increase the abrasion protection, though costs of fabric and resin go up. Other fabrics, such as Dynel and Xynole are commonly used on decks. Both drape over compound curves much better then regular fabrics and both are much higher in abrasion resistance. Unfortunately they also require a lot more resin to wet out, as much as three times more then similar weight conventional fabrics. In the end, you'll have to decide how much protection an area needs and how much effort or abrasion resistance you can afford. Dynel is about 20% more then regular fabrics, Xynole is considerably more and both will suck up resin like a whore outside a GM plant on payday. |
| These people answered all my questions and I like their prices. Also, in a 5 way test they came out on top. http://www.raka.com/ http://www.oneoceankayaks.com/Epoxresl.htm |
| Glassed plywood decks I was told at Fiberglass Supply where I picked up some System Three that one layer of 5.6oz would work. I'm not worried about adding strength so much as weather proofing but your point about wear resistance is a good one. I want to do some kind of non skid and that would help with the wear issue. Any good ideas for non skid on a glass and epoxy deck? Here is a link to a blog I started on this boat project; http://www.sailblogs.com/member/rebuildingmariner32/ |
| 6 ounce will work, but it's light so abrasion resistance will be limited. If you're attempting to put a 'glass sheathing over a laid deck on that old ketch, then you need to do one of two things. Replace ether decking substrate with plywood, then apply the 'glass sheathing or apply a much heavier fabric laminate. The reason is simple, a laid deck (a bunch of individually laid boards, fastened to the deck beams) has a lot of movement. This deck planking movement will rip loose from the sheathing creating a lovely place for rot to live, fester and raise it's ugly head in a few years. So, you have to lock it down with a much thicker sheathing and solid fastening to the deck beams (the old planking). In other words if the deck is marginal, remove it and replace with plywood, then apply a 6 to 8 ounce sheathing. If the old deck is in fairly good shape, insure the fasteners are tight and apply a thick sheathing (and hope for the best). How thick, well 16 ounces at least, better yet would be Dynel or Xynole, which have a much higher modulus of elongation and can absorb much of the movement before sheering loose. If I remember correctly Mariners were plywood decks with polyester set sheathings which as we now know doesn't work, though at the time the jury was still out on longevity. Epoxy should cure this issue. |
| The deck is not marginal, it's totally rotten and delaminated and I'm replacing all the original plywood. I guess in 1972 they didn't know about water proof glue and yes the original glass was put down with polyester. |
| The plywood was WBP glue (most likely), but even the best plywood will rot if subjected to moisture long enough. Use good marine plywood, fully encapsulated in epoxy, with a minimum of two coats (much better if three) on every surface, especially the edges. The fastener holes in the deck beams will also need to be drilled out, a dowel fitted (epoxied) and sanded flush. The majority of these holes will be shot (rot). Back in the era your boat was built, there was a run of plywood (from the far eastern countries of course) that used a fish oil based adhesive. It didn't hold up and a lot of boats had delamination issues, including major yacht manufactures. I owned one of these boats once and had to replace every bulkhead, cabinet, counter top, furniture, etc. Fortunately the hull and deck where 'glass. If your boat was built in the far east (it was, again if memory serves me), then all plywood should be considered "suspect" and replaced. |
| 9mm plywood cover with fiberglass | Jakjit Singh | Wooden Boat Building and Restoration | 29 | 10-05-2009 08:00 PM |
| Newby question regarding Epoxy and fiberglass redecking and plywood choices | baranx4 | Boatbuilding | 3 | 03-05-2007 08:55 AM |
| fiberglass on plywood | Jan Van | Boat Design | 6 | 07-25-2006 04:30 PM |
| that is the diference between plywood and fiberglass? | tamkvaitis | Boatbuilding | 9 | 12-27-2005 07:11 PM |
| Planks to plywood or fiberglass | ajoan | Wooden Boat Building and Restoration | 2 | 10-25-2005 05:09 PM |
