| how much epoxy just got plans for my first boat -8ft pram dinghy Need to know hou much epoxy and filleting resin i need i ordered today and the company told me i needed the following: 5kg epoxy resin 1 kg filleting 3"tape plus all the other bits and bobs that go with it this sounds alot to me or am i wrong? |
| Philip I could use a few more details about the boat you're building. I also have no idea what epoxy resin weighs. My guess is 5kg would equal about 1 ½ US gallons, +/- ½ gallon. This would be about right for an 8’ dinghy. For fillets you add filler material to the resin, wood flour, ground glass, talc, are just a few that work well. Mix it thick enough so the fillet won’t sag, but still spreads smooth. I’ll see if I can find some web references for you. I don’t have the writing skills to walk you through the whole process. Take a minute to register so I know who I’m talking to. Then tell us about your boat Gary |
| Philip: 5kg of resin is about 1 U. S. gallon which is about right for an 8' pram if you're also going to coat the hull with resin. You also refer to 1kg of filleting. If you're talking about the 3" tape, that should come out to about 120' or more. I don't know if your pram is a single or double chine or if you're supposed to add 1 or 2 layers to each side so I can't say if that's too much or not enough. Since you already have the plans measure the length of the chines and multiply by the number of layers you'll have to apply. Give us a few more details and we'll help you out. I built a Fireball (16' sailboat) quite a few years back with the stitch and tape method. It's really quite an easy and fast building method. |
| Epoxy crystallization | jfblouin | Materials | 4 | 09-15-2005 12:19 PM |
| Easier way for balsa core deck replacement? | pago cruiser | Boatbuilding | 4 | 06-01-2005 07:20 PM |
| Epoxy......how much i need? | {NW}BKUSA | Wooden Boat Building and Restoration | 7 | 01-21-2005 06:14 AM |
| Paint question over epoxy | zember311 | Boatbuilding | 5 | 11-26-2004 03:22 PM |
| Gelcoat over Epoxy | wet-foot | Boat Design | 9 | 08-16-2004 07:58 PM |
