| How to fix a new gun-whale rubber strip. Morning all, I need to fit a new rubber strip around the gun-whale of a fibreglass boat that I have been restoring for some time. I removed the old strip, removed all the old resin holding in place, and cleaned up the joint where the hull and deck join. I don't how many types of these strips there are, but this one is pushed over the fibreglass join and is held in place with epoxy or polyester resin. Now for the question what method/process should I use to fix the new one in place. How do I hold 14 meters of this strip in place or can I do a section at a time. The last thing I want is to stuff this up and end up with resin getting onto the newly painted hull and deck and the rubber strip not looking good. All help with this matter will be greatly appreciated. Regards Bruce |
| I just replaced the rubrail rubber strip on a Club 420 sailboat and used 3M 5200 sealant/adhesive. http://www.starmarinedepot.com/3M+5200+Sealant.html This is a flexible ultra durable adhesive that bonds to gelcote, fiberglass, wood and rubber. It worked very well. I think this method would also allow you to do in in sections or if you got some buddies to help you just goo it all up and stick in on there at one time and tape it up just to hold it until the 5200 sets up. Good Luck -Alan |
| Speed Strip tongue-and-groove strip planking | Jeff | Materials | 38 | 08-05-2009 12:12 AM |
| fixing a new gun-whale strip in place ?? | tropicrows | Fiberglass and Composite Boat Building | 1 | 10-17-2006 11:08 PM |
| identifying rubber on inflatable | w_water | Materials | 6 | 07-17-2006 12:29 AM |
| Whale-tail hydrofoils on small runabouts | marshmat | Powerboats | 9 | 08-24-2005 01:42 AM |
| polyurethane rubber | Materials | 1 | 06-29-2002 10:20 PM | |
