Old 06-02-2007, 09:30 AM
BWD BWD is offline
Rep: 128 Posts: 228
hobie 18 sx rudder repair
Hello.
I have a friend with a hobie 18 sx with broken rudder blades, right at the top. The forward upper corners broke off when boat was dumped in shorebreak....
I want to help fix these.
Wondering what adhesive might be compatible with the rudder material. It is a gray-black molded plastic, smooth surface, slightly "foamy" looking interior. No glass or carbon.
Planning to try epoxy, PU, and cyanoacrylate, but want to fix without cutting entire rudder up for samples....
If anyone has done this repair, I would be grateful for advice.
BTW also thinking of mechanically bolting it together with 1/4 SS mach screws into barrel nuts crossdrilled through stock -belt and suspenders.
Thanks.
-BWD
Old 06-04-2007, 12:42 AM
alan white's Avatar
Rep: 1168 Posts: 3,270
I know the material by your description. A hard foam within what is probably a roto-molded PE shell.
Very high stress area (and so it broke there!)
A replacement from the factory might be the most practical option, though I would imagine they charge enough.
Very hard to work with PE because it doesn't stick well to epoxy.
One option would be to make a fiberglass/epoxy shell to fit over maybe 8" of the rudder and bond that with PU adhesive. First I would adhere the broken-off piece by whatever temporary means are available, then grind that area thinner (so that a "jacket" of epoxy/glass will end up the same thickness after lay-up where the attachment to tiller, pivot, etc. are).
Then wax and cover with hefty-bag plastic, wrap with glass/epoxy, and when cured, remove the shell and re-adhere with polyurethane adhesive.
Most anything else you do will not take the stress, I think. This should work fine. Might make sense to cut the broken piece off after removing the shell. You could then fill the area around the holes with solid epoxy after drilling your first hole. The remaining holes can be drilled after that filler cures.
alan
Old 06-04-2007, 07:56 AM
BWD BWD is offline
Rep: 128 Posts: 228
So, you make a mold and then use the mold as the skin- interesting!
Will have to try this.
My friend does not want to spend the $200-300 for each repalcement blade (needs a new mainsail too....).
Will post results if it comes to gether. Thank you for the advice.
BWD
Edit: I think these rudders are skinned on lexan. May try solvent welding + glass tape overlay in either a Methylene Chloride/lexan soup or Weld-On 45 or 57 matrix, avoid making a mold.
Try this
1. bond broken tip back on with epoxy - just joining the core and getting things in position, but the epoxy will also protect the foam vs. solvent.
2. grind down skin around the repaired joint.
3. feather in lexan glop in MeChloride.
4. grind down the new plastic bump.
5. overlay glass tape in lexan/solvent matrix or adhesive matrix.
Old 06-04-2007, 10:54 AM
alan white's Avatar
Make it strong! Wow those new blades are expensive! Those things must break all the time. What a business!
Good luck.
A.
Old 05-25-2009, 09:58 AM
mrvalrico mrvalrico is offline
Hobie Rudder Repair
Hello,
I have sucessfully repaired hobie 18 and 16 rudders, let me know if you still are interested in doing this. They are getting hard to find, keep your old ones!
They are very efficient blades and can be used on other dingys and boats!
Yup!
John
Hobie Bravo Caldera Boats Multihulls 18 12-22-2010 07:49 AM
hobie tramps skyrunner06 Marketplace 0 03-12-2007 08:18 PM
Painting a Hobie 14 yankyfan100 Fiberglass and Composite Boat Building 3 07-12-2006 07:05 PM
Hobie Cat Snubber Multihulls 8 02-13-2006 10:10 AM
Hobie Mirage Drive JonathanCole Boat Design 9 07-08-2005 08:23 PM
