HELP! Hull is Sagging! I don't know what to do!
Discussion in 'Boatbuilding' started by CatBuilder, Mar 21, 2011.
  1. CatBuilder
    CatBuilder Previous Member
    I'm not moving the mold. Way too risky. Half hulls need to be perfect matches when joined.
  2. hoytedow
    Are the hooks as close to hull as possible?
  3. TeddyDiver
    Likes: 152, Points: 73, Legacy Rep: 1650
    TeddyDiver Gollywobbler
    Before the next hoist you could take your lifts to local welder and do a modification to get next half of easier and it might help also when you are lifting a half on top of another later..
  4. CatBuilder
    No, I can't. They will become derated and will not be able to lift the load without danger to myself and the hull.
  5. hoytedow
  6. CatBuilder
    Those are $6000 each.
  7. hoytedow
    Ouch! My heart! My heart!
  8. hoytedow
    Used ones?
  9. hoytedow
    Rented?
  10. hoytedow
  11. AndrewK
    Likes: 58, Points: 28, Legacy Rep: 344
    AndrewK Senior Member
    Yes, refer to green text. Also there are longitudinal floor and bunk top landings and shelves that can go in at this stage. These will act as stringers and prevent some of the sag as well as lock in the shape while the half is in storage with out the outer laminate.
  12. viking north
    Likes: 94, Points: 48, Legacy Rep: 1146
    viking north VINLAND
    Catbuilder, to gain a few inches simply add a short section to the lifting arms. This will reduce their lifting weights but i don't think this will be a factor in your case. Geo
  13. hoytedow
    Yes.
    This will work.
    Numbers are conjectural but the ratios are not.
  14. hoytedow
    No drilling, bolting or welding of original crane. These would be temporary extensions which slide over the original arms, held on with clamps.
  15. hoytedow
    Of course the front wheels of the base of the unit would have to be directly beneath the hook at the very least, otherwise it will tip forward, unless you add adequate counter-weights to the back.
