Old 02-23-2005, 12:05 AM
catxin catxin is offline
Rep: 10 Posts: 2
Help on first plywood lapstrake project.
I want to build the Japanese Beach Cruiser I found in a book by a man with the first name Phil, though I forget what the book was called, I copied the plans. The plans show the dimensions from top view and side view of the completed boat, to the outsides of the laps. It is supposed to be made of 6mm plywood. I don't know much about boat construction, and I am wondering how I could make a frame to build this hull on, or If I just need to do a lot of math to figure it out. it has good drawings, but I need to be able to cut all of the boards to the right shape and size. I'm guessing you won't want to explain the entire boat building process to me, so if anyone knows of a book that would definitely cover this project, that would be good. And I am wondering if I should use thicker plywood, if I should be going anywhere else than the open sea. Thanks for the help.
Old 02-23-2005, 12:33 AM
Rep: 2891 Posts: 8,798
The book you want is by John Brooks called "How to Build Glued-Lapstrake Wooden Boats". It will hold your hand through the whole process.
Old 02-23-2005, 12:39 AM
htom htom is offline
Rep: 10 Posts: 6
Probably Phil Bolger, in "Boats with an Open Mind". You should write to him and purchase a set of the complete plans, they'll make it much easier.
Old 02-23-2005, 02:09 AM
Rep: 10 Posts: 2
Thanks
Thanks for the quick reply, I'll definitely do both of those. I can't wait to be sailing out of San Pablo bay across to San Francisco, although I do have some other things to finish up before I get started on this project. I'll catch up on my reading though. Whenever I start a new project it's in a completely different field from my last ones, so I am a bit slow at them. I wouldn't think it's neccessary to take a sailing class to learn to sail. Perhaps I'll have a friend teach me. Phil claims this boat is fairly un-flipable, so I don't think I'd do any harm sailing around San Pablo with the storm sail up.
1956 ChrisCraft Project, your opinion please... PeterH Wooden Boat Building and Restoration 13 03-20-2005 06:53 AM
Boatbuilding plywood rdbct Wooden Boat Building and Restoration 3 02-05-2005 06:12 PM
Project managment/Design job available? Turkey and/or multihulls preferred. catweaselcat Services & Employment 0 11-20-2004 04:06 PM
mahogany marine plywood structure? blackspot Materials 13 10-06-2004 09:39 AM
Plywood specs from the user point of view amitk Materials 0 10-04-2004 12:13 PM
