Old 01-30-2010, 12:29 PM
Stadtline Stadtline is offline
Rep: 10 Posts: 4
Help! Drilling holes in fenders
Hello,
I was wondering whether anyone can help me with this!
I have bought D-section fender/rubbing strake and need to drill/cut holes of around 12.5mm. Cutting holes at teh top of the D and on the base will allow me to pass bolts through to secure to the hull.
I have tried traditional drill bits, but this makes a mess as the fender "gives" and the resulting hole is not clean at all.
Has anyone had a similar experience and found a solution to purchasing a suitable cutter?
Many thanks!
James
Old 01-30-2010, 12:56 PM
mark775
Use a hollow tube with OD sharpened. Silicon oil for lube. Make something like a gasket punch but allow room for material thickness and a means to get material out (like a hole saw but without teeth or if you can accept a little roughness, just use a hole saw) I have heard people try freezing first but that would make for an unruly snake! Would you mind elaborating about how you are going to attach to hull? Typically, one would run screws strait into the boat through an aluminum bar acting as a washer inside the "D" (it's kinda tricky to get it all lined up right with correct hole sizing throughout). If not feasable, fender washers at every screw but don't get too tight and get them all equally tight to not deform rubber. Use rubber plugs you cut out to fill holes, glue in place with color matching 5200. Most of the time, for "D" rubber, black.
Old 01-30-2010, 01:21 PM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
Might work better to sharpen the ID of the tube instead, if you have a round file or stone small enough to do so. And as Mark says, be sure to use lube.
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
Old 01-30-2010, 01:31 PM
welderbob welderbob is offline
Rep: 25 Posts: 13
we use to use a flat spade bit. the type carpenters use. You may want to use a plastic strip (1/4" starboard?) inside the "D" rubber. Over time the S/S bolt will eat thru the aluminum strip.
Old 01-30-2010, 02:42 PM
alan white's Avatar
alan white alan white is online now
Rep: 1211 Posts: 3,325
They make hole saws that small. Use the thin-wall type, which is usually cheaper anyway.
Old 01-31-2010, 05:23 AM
Rep: 10 Posts: 4
Thanks for the advice. Will have a look at all options and have a go! Thanks again!
Old 01-31-2010, 10:51 AM
Rep: 1493 Posts: 7,447
A sharp spade bit is cheap and works great.
Old 01-31-2010, 11:15 AM
alan white's Avatar
Spade bits do require a material that is solid enough to keep the pilot centered.
Also, the bits also are prone to grabbing suddenly in certain situations. If a wood backing is used to support the pilot point, spade bits are, as said, quick, cheap, and effective.
Old 01-31-2010, 12:38 PM
Rep: 10 Posts: 4
Thanks for the posts...will get one of each and give them all a go.
Thanks again!
Old 01-31-2010, 03:21 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
I've never done it but a soldering iron comes to mind.
Avoid the fumes.
-Tom
Old 02-01-2010, 01:42 PM
Rep: 10 Posts: 4
I went out and bought a spade bit at 12.5mm as it was the easiest to source and it has worked perfectly! The pointed bit located well and helped make a clean cut by providing a pilot.
The fender I have is quite rigid. Softer versions may not give the same success in case anyone else has a go. But definetely worth a try on a bit of offcut and the spade bits are only a pound or so!
Many thanks for all your posts
Old 02-01-2010, 01:53 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,355
Perhaps you can quickfreeze the drill locations on the spot just before drilling by applying dry ice, being very careful, directly to the target.
Hoyt
Old 02-02-2010, 02:17 AM
mark775
An idea worth trying (I will, next time I do this). If I wanted the whole thing cold, I could take it outside! It's not "Florida cold" - but it is cold! Everything's crunchy/squeaky here tonight...
Does boat Fenders / Bumbers have to be round ? Fanie Boatbuilding 5 11-21-2008 09:29 PM
Holes in aluminium philzero44 Boatbuilding 10 05-30-2008 08:01 PM
Drilling Fiberglass?? Capt. Chris Fiberglass and Composite Boat Building 34 01-08-2008 07:16 AM
little holes in hull harveydoryguy Fiberglass and Composite Boat Building 8 03-30-2006 11:20 AM
Holes predator Materials 3 12-18-2005 11:44 PM
