| Heat Pump => Vacuum Pump I’m having to replace my house’s heat pump. Would the compressor unit make a (serviceable) vacuum pump for fiber/epoxy work?
__________________ Inquisitor Rocket Scientist or Space Cadet... you decide! |
| NO. Because AC compressors have the oil circulate with the Freon. You will empty the crankcase in a few minutes and blow oil everywhere. |
| Is yours a sealed crankcase? Rather than the open crankcase used in most home AC compressors. |
| If your pump has separate refrigerant and oil circuits it would probably be workable. If it's open crankcase (refrigerant is also lubricant) then all you'll do is shoot refrigerant into your garage and burn out a motor. You won't get nearly the vacuum that you can with a real vacuum pump, but if your unit is of the right type it could be serviceable.
| An air cond only pulls enough vacum to bring the evap plates down to 35F to keep water condensing on the fins from freezing. Any fridge goes to much lower vacum to service the freezer section. Old refrigerator cans work very well at reasonably small pull down areas. There not big enough to pull all the air out of a hull moulding in reasonable time. But do GREAT if a shop vac is used for the "big" air removal and all they have to do is the pull in. Although its not OK for Boeing or Air Bust , a shop vac does a fair job at small stuff all by it self. It will not compact laminate , but to stick a 3/4 thick foam into epoxy grout to repair a failed composite deck. FAST FRED |
| It's free, give it a whirl, you'll need a vacuum-gauge anyway. Yoke. |
| Solomon Technologies - "Electric Wheel" electric motor propulsion systems | lockhughes | Hybrid | 228 | 10-12-2011 05:00 PM |
| vacuum pump | miniscool | Fiberglass and Composite Boat Building | 14 | 01-29-2006 11:27 PM |
| Option One - how big | Willallison | Option One | 43 | 12-20-2005 06:44 AM |
| 12v Bilge pump timer/delayed shut-off...? | paularey | Sailboats | 5 | 11-04-2005 03:39 PM |
| Fuel Pump or no? | seaARK03 | Powerboats | 4 | 10-26-2005 06:18 PM |
