Old 01-07-2009, 07:44 PM
sam shepherd sam shepherd is offline
Rep: 10 Posts: 8
Green Materials
Hello everybody,
I was hoping to open a discussion on green boat building materials and green techniques of building. What are the least damaging materials to the environment to use for large vessels (say over 40-50m), and are there any techniques for building that are environmentally friendy. Does going green relate to a much more expensive product? Will it be economically viable in the near future? I am just trying to research the boat building industries carbon footprint and would love to hear some experienced opinions.
Thanks
Sam
Old 01-07-2009, 08:36 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Most certainly not! While there are companies out there pushing "green" materials and technology that costs a fortune, if you're really interested in minimizing the environmental impact of your build, you'll be looking for locally sourced materials, often recycled or used materials, stuff that hasn't had an excessive amount of factory processing and that hasn't been shipped back and forth in multiple trucks and trains. If current theories of economics make any sense at all, taking out all that "value added" transport and processing ought to reduce your costs, if anything. Where there will be added costs is in cleaning up old-tech equipment such as engines and refrigeration loops to meet new standards; the standards are evolving quickly right now and it's expensive for manufacturers to keep up. Once the requirements stabilize somewhat and the various technologies involved become more widespread, the costs will drop, just as has happened with EFI, catalytic converters, PCV systems, and all that jazz.
Jeeperz. Big boats! Wood's renewable, at least if you buy it from folks who are managing the forests sustainably. (That's not hard to do, just ask some of the better logging firms in northern Ontario, who are finding that it's more profitable long-term to harvest sustainably and keep the ecosystem reasonably intact so that it can regenerate. Look up the Forest Stewardship Council.) But it's hard to build 50+ m ships in wood. Recycled steel is plentiful, and brings substantially less (although not zero) environmental impact than virgin steel. Same for recycled aluminum; the recycling techniques for that metal are now good enough that the difference from virgin aluminum is only noticeable with ultra-thin anodized finishes, and even then just barely so.
On the designer's end, there's plenty of opportunity to try to extract the best possible fuel economy out of the ship. Even if the build costs go up slightly, the owner's fuel bills can drop dramatically, and he then has the added benefit of being able to advertise that he's doing what he can to be low-environmental-impact. Look at Steve & Linda Dashew's FPB 83 prototype, Wind Horse, compared to a typical 40-tonne production motoryacht as an example of how changes in design philosopy at the front end can translate to substantial reductions in both the owner's operating costs and the pollution produced by the vessel.
It's economically viable now. If you start from the beginning of the design phase, a commercial or institutional building (projects I'm familiar with) or in your case a big boat can be made much cleaner and more efficient at very little added cost; the extra cost of a few of the advanced systems gets paid off by the energy savings over the years. There's no reason why a boatbuilder should need to increase his costs significantly in order to clean up his environmental impact. It's more a matter of being aware of your supply and waste chains, and changing old habits accordingly. I know of at least one major construction project where less than 2% of the construction debris ended up in landfill. It was all sorted, recycled and resold at minimal net cost.
I wouldn't call this an "experienced opinion", but I am a LEED AP and have worked on two solar cars and several "green buildings" projects. The principles of 'cleaning up your act' are essentially the same regardless of which industry you're looking at, although the actual technologies and solutions chosen will be different.
Old 01-07-2009, 08:44 PM
Rep: 10 Posts: 8
marshmat,
cheers for a quick reply. Im interested in the recycled aluminium. Would you think that using imported recycled aluminium from across the globe would be better than using virgin aluminium from the location of build. I suppose where I am going with this is what energy costs are involved in the recycling process. All the best
Sam
Old 01-07-2009, 08:51 PM
marshmat's Avatar
Here's a report from the US DOE on the energy intensity of aluminum production: http://www.eia.doe.gov/emeu/mecs/iab...um/page2e.html It's about eight years out of date but the processes haven't changed significantly in that time. Ballpark figures: try about 4 kg of bauxite, 13 kWh of electricity and about 0.5 kg of petroleum coke for every kilogram of virgin aluminum. For recycled, about 0.6 to 0.7 kWh per kg of aluminum. By going with recycled, you're saving 12 kWh and 0.5 kg of coke for every kg of aluminum; this would have to more than offset all the transportation fuel. (Which it probably will, but you'd have to do the calculation for your particular case.)
Old 01-07-2009, 10:23 PM
Rep: 2891 Posts: 8,789
Duct tape and empty milk jugs. Lots of milk jugs if your need armor plate . . .
Old 01-07-2009, 10:33 PM
rasorinc rasorinc is offline
Rep: 678 Posts: 1,127
I'm a wood man. In the Pacific Northwest you have Douglas Fir, Western Larch, Alaskan Cedar plus a few other boat building woods. Wood lasts generations when taken care of and now with epoxy it can last hundreds of years. Just my vote on materials. All of these lumbers are farmed trees. Be very careful of recyled aluminum if it is imported--They can lie about the grades and do. You have some great wood for boat building in OZ
Old 01-07-2009, 10:50 PM
Rep: 10 Posts: 8
geez,
great info guys. can a wood hull compare to an aluminium hull for a luxury motor yacht? getting the curves right would be very difficult i would imagine. A vessel from wood would cost alot more wouldn't it? Are there ongoing maintenance costs that are significant? Do you know the main plantations used in the marine industry?
Old 01-07-2009, 10:51 PM
Rep: 527 Posts: 792
The US is currently growing ~9 billion (9 thousand million) board feet of lumber in the Pacific NW every year; yet currently harvesting only ~1 billion board feet. Please, use some lumber before it just burns up
Jimbo
Old 01-07-2009, 11:00 PM
Rep: 10 Posts: 8
jimbo,
do you have any sites that sell that lumber?
Old 01-07-2009, 11:01 PM
Wood will cost less than aluminum. The curves will look and be better. The maintenance is the same if done right with epoxy. The strength of wood is greater than aluminum. And you need less flotation. Need I say more. Use ironbark (eucalyptus) which grows in your backyard and is farmed. Wood is at it's lowest cost in over 40 years. You can fill a small container for under $6,000.00 and shipping costs are way down also.
Old 01-08-2009, 02:04 AM
Epoxy's base chemicals are petroleum based, so not so green after all. The trees are harvested with lots of diesel sucking machines, also not very green, though renewable.
Vessels of 120 to 150+ feet can't be made of wood very economically, compared to other materials, even with modern methods, goos and techniques. There's nothing especially economical about a vessel this size.
Sail power and alternative energy sources will help lower operating cost, but building realistically, vessels of this size are so well out of the realm of "pleasure craft" that being "green" is purely advertising fodder. This is particularly true when it sucks down more fuel in 5 minutes of operation, then a year's fuel supply for the average pleasure craft (about 10% it's size).
There are only commercial and naval applications for boats of this size, other then the opulent flaunts of the ostentatious. It certainly is a consideration for both the commercial and naval fleets. The latest breeds of naval and commercial craft have been addressing efficiency to a fairly high degree. No one, (business or government) wants to pay more for operation then they have to, but doing so "green" just isn't cost effective yet.
Mandates and legislation will change this, but as yet very little of this has occurred. Once everyone is completely convinced we are over the "hump" in oil production, then we'll see some huge gains, because we'll be on the downward slope of oil reserves. Currently, there's considerable debate as to when the hump will be reached. Personally I think we've just crossed it, but many suggest this will not occur until 2010 - 2012, with some head in the sand types thinking this will be in 2030. When everyone is on the same page and sucking the dregs from the bottom of the current holes we've drilled, things will change quickly. In the 10 years following this "revelation" just about every imaginable alternative fuel source will be seriously developed by the same stalwarts of the current energy suppliers.
As far as "green" ship building, well, it's the least of their concerns right now, so research is quite limited, but this too will change.
Maybe once they figure out how a barnacle manufactures it's glue, we'll be able to use seaweed and a synthetic version of this goo to laminate kelp ship hulls (reinforced with synthetic silk), with genetically enhanced bamboo superstructures, propelled by cloned super sized octopus that have been breed to cling to the ship and drive it on command (or electrical shock).
Old 01-08-2009, 05:17 PM
Rep: 10 Posts: 8
ive used those octopi, and they work great, for some reason the female is better than the male. I understand that "luxury pleasure craft" are ridiculous but the fact is that more are being made now than ever. The chinese have got a taste for them and there is no turning back, these superyachts will continue to be made and if we can help to reduce the carbon footprint by any means it would correspond to quite a savings to the environment. I have not found many "superyachts" that are made from wood, and im sure that the cost of build is far too high and i am wondering if it is at all possible? what are the limiting techniques, given that cost is not a factor? thanks for your comments PAR.
Sam
Old 01-08-2009, 06:46 PM
I know of a 150' strip planked ketch, done in the last 15 years.
Yes, there are a surprising number of mega yachts being built, but their concerns with being green has typically taken a back set to looking cool and being bigger then the film producer, next door neighbor's recent purchase.
China will be the last to go green. They'll "span the gap of empty oil well holes with the bodies of workers", before thinking about green anything. You're talking about probably the most potential for decades of environmental abuse the world has ever seen, making even the USA's abuses pale in comparison. They're just at the beginning and their social and political arrangements are just ripe for long term, undisclosed abuses that could take centuries to dislodge.
Green and China in the same sentence is much like mentioning ethics and politicians in the same breath.
Old 01-08-2009, 07:24 PM
hear / here Par
Old 01-08-2009, 08:54 PM
kerosene kerosene is offline
Rep: 157 Posts: 406
Originally Posted by sam shepherd View Post
marshmat,
Sam
As far as I know by far most (80-90%) aluminum is recycled - processing virgin aluminum is extremely energy intensive thus recycling is pretty efficient.
As a result using "recycled" aluminum doesn't really provide much difference to just "normal" aluminum boats.
Aluminum is not very eco-friendly at all.
edit: marshmat cover aluminum's issues already. Just wanted to add that with this kind of material that is efficiently recycled the use will directly result in need of more virgin material. While one could boast that he uses recycled material its not really that good if more needs to be mined to replace it.
Green Race Proposal ancient kayaker Sailboats 3 01-02-2009 04:58 PM
Green Gas? Delta Open Discussion: All Things Boats & Boating 6 04-22-2007 09:41 PM
Green horn needs lots of help Roger Brooks Fiberglass and Composite Boat Building 0 01-17-2006 07:52 PM
looking for Mr. Phil Green Parvisernie Open Discussion: All Things Boats & Boating 2 08-21-2005 09:53 PM
New and green CPM Fiberglass and Composite Boat Building 3 02-18-2005 09:52 PM
