| Glued Lapstrake I am hauling my old boat down from Lk Superior this Fall and it will be several more years before my new project boat is ready to go back up. I need to build a little day sailer in the interim. A Gaff Rigged Cutter. Double Ender. Lapstake. A pretty little boat that will make me forget that I can't afford a Westsail 32 or 43. I have ordered study plans from Selway Fisher in the UK for such a 16 ft boat. For complete plans I have to decide whether to order the strip plank version plans or the Lapstrake version plans. I have built strip planked boats but I would like to try plywood Lapstrake. I would want to glue the lapstrake. I would want a nice painted final appearance. I would welcome opinions as to whether the seams should be clamped, screwed or stitched. Also whether I should glass the hull. Finally, this boat could be left in the water, I know West 407 filler shouldn't be used below the waterline. Is there a better seam filler short of silica? P.S. What's your favorite glued Lapstrake reference book? Jim Herbert |
| Hi Jim, There was a three part series in Wooden Boat magazine several years ago that delt with the construction of a 22 foot plywood lapstrake double ended cruising sloop. There are some decent photos within the arcticles. They did glass/ epoxy the finished hull. I have the issues but their exact location is a mystery. A little research would dig them up. It was a Ian Quoghtred (sp?) design named "Grey Wolf" I think, not quite like your building, but same basic technique. The above type boats do have a certain charm & inheirently seaworhy look about them. TGoz |
| The name was "Grey Seal" Seams are clamped with simple homemade wood clamps. If you use good quality mahogany plywood you can skip the outside glassing, always a nuisance on lapstrake hulls. Marco. |
| Ian Oughtred has written a good instruction book, and this together with his plans are available through the Wooden Boat magasine. http://www.woodenboatstore.com/prodi...number=325-116 I don't know anyone else that does lapstrake ply as well as Ian. But as Marco says, don't skimp on the quality of the ply. |
| Oh, if its helps, you should perhaps regard not being able to afford a Wetsail 32 as a good thing. It will save you the heart ache of trying to get one to sail, especially after the sparkling performance of one of Ian's designs. |
| Glue for lapstrake | FrankThomas | Wooden Boat Building and Restoration | 6 | 01-13-2006 08:32 AM |
| Composite replacement of a edge glued strip planker | Roly | Fiberglass and Composite Boat Building | 18 | 10-15-2005 12:56 AM |
| Lapstrake Scantlings | AWolfe | Wooden Boat Building and Restoration | 20 | 02-23-2005 05:21 AM |
| lapstrake in fiberglass | richard | Boatbuilding | 5 | 01-14-2005 04:41 PM |
| 1 part boats-no glued flanges? | seamonkey | Fiberglass and Composite Boat Building | 0 | 09-27-2004 12:51 PM |
