Old 04-04-2008, 01:12 AM
gatortennis gatortennis is offline
Rep: 10 Posts: 7
Glassing In Port Holes of 37' Hatteras
I was wondering if I could glass in the port holes on the sides of the hull of a 37' Hatteras sportfish by removing the hardware, applying a couple sheets of glass on the inside, then filling in the hole with marine putty such as isophathalic putty and then sanding, priming, and spraying with Awlgrip?
Or, What is the recommended way to do this?
Old 04-04-2008, 08:33 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 604
Treat it like any fiberglass repair. There's some good videos from Jamestown Distributors on YouTube that show you every step of the process.
http://www.youtube.com/watch?v=6N7YMr6E564
Good luck. Post some pics as you go.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
detroit 6v53 power on hatteras scubajohn Diesel Engines 12 01-14-2012 11:14 AM
Hatteras Refit Video cleaniedini Boatbuilding 0 01-14-2007 11:31 PM
windows and port holes fishweed Fiberglass and Composite Boat Building 0 08-04-2006 01:00 PM
help with hatteras rebuild scubajohn Boatbuilding 5 04-16-2006 02:19 PM
afordeble port holes (skylite) kalleo Boatbuilding 1 12-24-2005 12:08 PM
