Old 01-17-2011, 02:30 PM
mark.k mark.k is offline
Rep: 10 Posts: 2
glassing in plywood deck replacement
Hi
I am currently in the process of refurbing a number of old displacement boat, the boat have all been left for a number of years and are well rotten!
Basically all the boats bulkheads bearers and engine beds have now all been replaced and I am onto the deck having cut it all in today I am just wondering what the options that I have not considered are.
To provide the strongest long term solution do i need to cover the underside of the deck in a layer of chopstrand and then flow coat it? or can I treat it in some other way that will be quicker? I will of course be taping the top and laying a couple of layers of 2oz csm on the top and same with the taping.
Basically I am just after another opinion?
My favourite way of finishing decks is flowcoat with a kiln dry sand in it as it provides alot of grip and I think it looks quite smart but does anyone have any other techniques they like to try?
These are the first smaller boats I have worked on for a while having only really worked on really big stuff! what lay up would you have used for the engine beds to the hull to support a 3 cylinder volvo? you can never be to careful and is fully braced with other bearers anyway and will also have the floor glassed to the sides but just thought I would ask!
There seems to be alot of knowledge on this forum and thought I would ask you guys
Many thanks
Deck replacement question - Plywood fit? thill Fiberglass and Composite Boat Building 15 02-28-2012 01:47 AM
What oz cloth for glassing over 1/2" plywood? mosquitolaGOON Fiberglass and Composite Boat Building 6 04-19-2008 08:29 AM
planking or plywood and glassing a hull verboon Boat Design 13 02-08-2008 10:28 AM
Glassing Plywood tie phoon Wooden Boat Building and Restoration 10 02-11-2007 03:40 PM
Deck replacement Busted Knuckle Materials 0 03-31-2004 04:02 AM
