#31
I am leaning toward foam, but maybe the supplier was just telling me it would crack because he didn't want to exchange it? Sure wish I had first hand experience to know... there's always so much conflicting information when building a boat.
__________________ "You can't solve all of life's problems with epoxy" - My Wife |
#32
I see you have some drama with moving large stuff, I include some pics of my trailer- I built it for about $3400 Aus, its purpose is multiple- to store my tooling on when I had no shed- then as the basis of a laminating table for large flat sheet molding, teamed up with table frames & melamine sheet pictured on top- then also for the stongback basis of underwing melamine sheet mold, then for the support cradle to underwing for transport to water. this trailer measures 11M x 1.8M (37' x 6') + the guards/wheels, its been very handy for other moves too. All the best with your building from Jeff. |
#33
| Balsa sheet is not the ideal material for your type of build. But if it is your preference it can be done, provided the camber is slight and constant right up to your deck radius. In a lot of cases the camber increases as it transitions into the deck radius this is the zone you could have splitting in, if this is what you have. In a typical fine catamaran hull last two feet at the bow will give you problems, but even in foam you will need kerf cuts there. |
#34
| Thanks, guys. I think I'll go with easy. Foam it is! I'll worry about replacing core on the deck when I get to bedding hardware. Cross that bridge later on. Does anyone have any suggestions for a good deck foam? I'm thinking of the following priorities: 1) Closed cell 2) Stays bonded 3) Low Cost 4) Not Friable 5) Handles compression loads well (for smaller things) What core would you suggest, knowing I'm not buying any more Core Cell at $5.++ per square foot? The Core Cell I did get was bought at $3/sqft or so. I'm looking for something cheap like that.
| Best place to buy Core-cell | Carolina Flare | Materials | 6 | 05-01-2011 02:01 PM |
| coosa core in place of plywood | adventuris | Fiberglass and Composite Boat Building | 7 | 02-05-2009 08:02 PM |
| Balsa core vs. foam core | James Maldonado | Fiberglass and Composite Boat Building | 23 | 01-21-2006 10:12 PM |
| Getting ready to Finish Hardtop--some questions for the pros | searaytuna | Fiberglass and Composite Boat Building | 2 | 11-19-2005 03:06 AM |
| nida-core questions | donjames | Materials | 5 | 11-08-2004 09:24 AM |
