Old 03-05-2005, 11:19 PM
mattotoole mattotoole is offline
Rep: 10 Posts: 197
Gelcoat vs. paint (LP)?
I'm wondering about re-gelcoating vs. painting (LP). Everyone tries to make their gelcoat last as long as possible, thinking that once it's painted it will never be the same. But I'm not so sure. LP is pretty neat stuff. Which do you think is better, not so much for initial finish quality, but durability, repairability, color matching, etc? How about re-gelcoating vs. painting?
Old 03-06-2005, 04:55 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
LP needs less (none) upkeep work, wash it once in a while, no waxing, rubbing, polisshing. My painter (a car paint shop in the sae house) sais that regular car paint lasts at last five years (on boats), while LP lasts more than twice as long. Of course this depend on the environment, we don't have much uv radiation here, 60-70 degrees north.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 03-06-2005, 10:43 AM
Capt. Chris Capt. Chris is offline
Rep: 10 Posts: 67
mattotoole,
LP is the way to go! I am in the process of finish a project and am using a waterborne LP. It is a llittle tricky to spray, but once you get it down it looks great and is rock hard. In my opinion re-gel is old school at this point in time as the technology in coatings has advanced so much just in the past few years. I think it has its place in new boat building because this is the process it was designed for. Good luck and save up some $ ... LP coatings with the primers are mucho bucks!
Capt. Chris
Old 03-07-2005, 01:13 AM
mojounwin mojounwin is offline
Rep: 10 Posts: 58
Just a question from a newie,
What does LP stand for? Is it linear Polyurethane?
Old 03-07-2005, 01:23 PM
SamSam SamSam is offline
Rep: 464 Posts: 1,608
This isn't about gel coating vs. painting (don't even think about re-gelcoating) but just to suggest maybe you don't need to do either. If your gelcoat looks bad, maybe all it needs is to be attacked with a buffing/polishing compound and a buffing wheel to remove the haze and then re-waxed.
Old 03-08-2005, 01:46 AM
Rep: 10 Posts: 197
Well, that's always been the attraction with gelcoat, it can always be renewed. But only up to a point. After 20-30 years a lot of boats look pretty faded and tired, and only a fresh coat of somthing will do the trick.
Spraying gelcoat over gelcoat alexhiguera Fiberglass and Composite Boat Building 9 08-26-2005 11:09 PM
gelcoat over paint gofishing Boat Design 2 04-12-2005 09:20 AM
awl craft vrs system three lp paint water20 Fiberglass and Composite Boat Building 1 01-13-2005 10:31 AM
I need HELP! AWLGRIP PAINT OVER GELCOAT chkmahow Materials 2 06-27-2004 12:14 AM
Gelcoat Peeling&Bottom Paint Stripping Marlin111 Services & Employment 1 01-01-2002 07:01 PM
