Old 03-13-2008, 06:15 PM
Roly Roly is offline
Rep: 222 Posts: 471
Sorry Fanie, was quoting Landlubber.
I only have a sharp with a 2.4 tip gravity feed.
Dunno what a putty gun is. But I am blending gelcoat soon, where I marry deck to hull (rebate) , so I better find out.
Either that or spray with PU.
Old 03-13-2008, 08:46 PM
the1much's Avatar
the1much the1much is offline
huh? hehe ;)
Rep: 547 Posts: 3,949
if your just doing that small of an area,,,and your gonna have to sand no matter what,,,wouldnt it be easier and faster to just brush it on?
hehe ,,,,,Jim------>
Old 03-13-2008, 09:09 PM
Rep: 222 Posts: 471
Yeah probably......but I never get to use my gun.....
68' x 4" wide = 22ft^2 is a bit of gelcoat??????? (34' boat)
F@(K hope I have enough left!!!!!!
22 /11 = 2m^2 Yup, i have enough (1L @ 0.5mm thick)
Thx, 1much, for getting my grey matter 2 work.
Guess i'm gonna be doin some cuttin 'n polishin.
Will I have to put some clear resin on top to get the same lustre as the molded gelcoat???
Will post some pictures (if this sounds like gibberish), as we pop the deck tomorrow.
Yahhoooo....oooooo
Last edited by Roly : 03-13-2008 at 09:20 PM. Reason: guess this boat may actually make the water.............
Old 03-13-2008, 10:01 PM
the1much's Avatar
huh? hehe ;)
nope,,you'll need to wet sand it,,then buff it,,,then you'll wanna do the rest of ya boat to match hehe
Old 03-13-2008, 10:31 PM
Rep: 222 Posts: 471
With my fingers and toes crossed..... if I can get it as good as the deck I'll be happy! (I haven't seen it yet but we buffed the mold for hours and waxed 5 separate times.)
Old 03-15-2008, 07:43 AM
Rep: 95 Posts: 462
a putty gun is just another name for a primer gun with a large tip you can buy a gun with a 2.0 or 2.5 tip and will spray gelcoat, a dump gun with paper cups is best, they also sell a dump gun with a contaner that holds 8 litres and is feed with a tube you just have t hang the bucket of gel higher ie gravity feed,
Old 03-15-2008, 08:27 AM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
fibreglass jack, yeah, thanks mate, and also the question about sytrene making resin yellow, yes that can happen, just don't thin too much! Not needed anyhow to be like milk, we are not spraying finish coats here, just gelcoat.
Old 03-15-2008, 03:56 PM
Rep: 222 Posts: 471
Came out pretty good all in all. A little imprinting of faults in a mold (that hasn't been used for 25 yrs). The odd void under gelcoat where the fancy cornice molding is, and styrene attack on the transome where gelcoat was too thin.Our block off of the mold (transom/coaming) was cheap & cheerful so gelcoat work to be done there as well.
Gel coat spray systems-dscf0008.jpg  Gel coat spray systems-fresh-out-mold.jpg  Gel coat spray systems-transomcoaminingremoved.jpg
Gel coat spray systems-25yrs-out-use.jpg  Gel coat spray systems-sweetas-.jpg
Old 03-15-2008, 04:04 PM
the1much's Avatar
huh? hehe ;)
im surprised it came out that good,,,,considering the dude in the picture has feathers comming outta his ass hehe
  #25
Old 03-15-2008, 04:24 PM
Rep: 222 Posts: 471
Now that you mention it, he sounded a tad gay. Who cares, he was pretty good on the hiab and didn't "crack my deck."
BTW, check the deckmold b4 we got to it. Cow pats 'n all!
Thanks for all the help from you guys. Especially Waikakikin (jeff).I'm pleased with the transom mod.
  #26
Old 03-15-2008, 04:38 PM
the1much's Avatar
huh? hehe ;)
now remember,,,,sounding gay is better then being,,hehe
and you should frame the "before" pic.,and leave it hanging in the boat,,,and do i hear a boat name emerging??( cow mold) hehe
  #27
Old 03-15-2008, 05:46 PM
tinhorn's Avatar
tinhorn tinhorn is online now
Rep: 253 Posts: 526
Man, that is sweet!
(I always get a bit misty-eyed at birthings.)
  #28
Old 03-16-2008, 09:11 AM
Landlubber's Avatar
Is it a Cavalier?
  #29
Old 03-16-2008, 02:46 PM
Rep: 222 Posts: 471
'69 Stewart 34
http://share.shutterfly.com/action/w...r&linkid=link4
There is one in NSW somewhere. Googled gave ........ "Pendragon" 1996 Sydney- Goldcoast. built by Graham Fluery.
Otherwise a strong class following in NZ. They are now sponsored by Hyundai. (Was Canon for 25yrs)
  #30
Old 04-23-2009, 02:21 PM
WorWilly WorWilly is offline
Rep: 10 Posts: 11
Hi guy's you talk about small area spraying, what do you use with larger moulds, there appears to be many sytems on the market, internal mix, external mix, which is the best system. Also I agree gelcoat should never be thinned.
wrinkles in spray-on gel coat repair? mac26d Materials 4 09-15-2007 05:27 PM
a little help spraying gel coat ANGELMAT4 Fiberglass and Composite Boat Building 25 12-16-2006 12:28 PM
gel coat instead of toolin gel ? meredog Fiberglass and Composite Boat Building 5 08-10-2006 09:53 PM
Gel coat jeremyb251 Materials 1 03-16-2006 01:40 AM
I cracked my Gel Coat scarmack Fiberglass and Composite Boat Building 4 06-08-2004 04:54 PM
