#46
| Hey tunnels... ive been using pva alot to break my moulds in but i always do it till i can see it and i have a blue film i can then pull off afterwards... As you say should i mix mine with water and spray it on then? the only problem i can see is what if i miss a bit and not being about to see the coat it would be hard to tell? spray then dry and the gel coat? Thanks |
#47
#48
| Sounds like a good plan. I know it's asking alot from you tunnel but do you recan you could write me a quick guide and mixing the Pva with the water etc. Only if you get the chance would really help me out. Thanks |
#49
| Hi Tunnels, your advise is always interesting, but is not always easy to understand you ( to say the least ) maybe due to the fact english is not my native language but it could well be that the same happens to you or indeed any other reason but I always find your english "formulation" difficult to understand .. which is a shame |
| gel coat,...who needs it!!!! | roscoewalsh | Fiberglass and Composite Boat Building | 11 | 09-02-2009 09:33 AM |
| Gel coat | nrodes | Materials | 13 | 01-25-2009 10:54 AM |
| gel coat | alfiej44 | Fiberglass and Composite Boat Building | 10 | 09-05-2008 06:16 AM |
| gel coat instead of toolin gel ? | meredog | Fiberglass and Composite Boat Building | 5 | 08-10-2006 08:53 PM |
| Gel coat | jeremyb251 | Materials | 1 | 03-16-2006 12:40 AM |
