| "As for the sanding off, wash the surface with detergent in water, and start to wet and dry the surface, do not rub out the dimples, just do whatever you feel liiks right. Once you have sanded down, using say 240 wet and dry, then wash off the soapy water and dry." Nice to see your got the result you needed........addition of soap certainly helps the paper to work.
| Help w/ gel coat on 85 cobia!!!!!! | tapoutking | Boatbuilding | 15 | 09-25-2007 05:32 PM |
| a little help spraying gel coat | ANGELMAT4 | Fiberglass and Composite Boat Building | 25 | 12-16-2006 12:28 PM |
| gel coat instead of toolin gel ? | meredog | Fiberglass and Composite Boat Building | 5 | 08-10-2006 09:53 PM |
| Gel coat | jeremyb251 | Materials | 1 | 03-16-2006 01:40 AM |
| Gel Coat over aluminum? | SamAlec | Metal Boat Building | 6 | 08-12-2004 01:10 PM |
