Old 09-24-2007, 08:41 AM
Captain Pugwash Captain Pugwash is offline
Formula for Boat Length Vs Beam
Hi.
I know there is not going to be an exact answer here, but I'm looking for a general guide for how the length of a boat affects it's beam.
For example, if you have a 12 metre motoryacht, then what would be it's likely approximate beam. If you had a 14 metre motoryacht, is there a general formula that would support what it's beam would have increased by - and so on.
Is it linea, or does the ratio/formula alter as you move towards 20m+ boats, etc.
I am looking for the general ratio/formula for both sailboats and motoryachts.
Can anyone help?
Thankyou
CP.
Old 09-24-2007, 09:17 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
It's not possible to find a simple formula.
You can try to collect data from boats you like and put them in a spreadsheet. Then if you plot beam vs length you will see the dots are spread around a curve, maybe. Short boats have relative more beam than long boats. L=2.5 x B for a small dingy for example.
It's more like this:
You want a boat of a certain size to carry something, or you want so many bathrooms etc, then you find you need a certain length and beam, then you estimate weight, and if you want a specific speed you estimate power, add more weight for the engine(s) and fuels and start again.
For a given length, displacement, speed and power there may be an ideal beam, but most boats are compromises as you know
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 09-24-2007, 09:20 AM
Raggi_Thor's Avatar
From http://www.cyberiad.net/library/mult...p/multipep.htm
www.MBOATS.no
Length : Beam Ratio's Willallison Powerboats 5 03-20-2006 10:31 AM
VPP for low length/beam ratio tandu Software 0 01-18-2006 08:14 AM
Beam to length ratio? Danielsan Boat Design 28 03-05-2005 01:14 PM
Hull Waterline Length to Beam longngone Boat Design 12 10-22-2004 12:37 PM
Universal Displacement/Length formula sharpii2 Boat Design 0 06-04-2004 02:51 AM
