Old 06-12-2011, 08:58 AM
Pylasteki Pylasteki is offline
Rep: 35 Posts: 52
Flat work benches.
Hi Guys,
I'm wondering those of you who are laminating up panels, and vacuum bagging what sort of work bench you've built to keep things flat!
Its a pain, as you can't really joint anything with a powerplane without a flat reference under it... or glue up much of anything.
Here lately I've been laminating straight stuff up on lengths of aluminum box tube, but its a pain in the rear...
My last big bench was 5ftx9ft, for storing plywood stacked flat under it... 3/4 top with 2x4 supports. Not quite strong enough when loaded, as it would sag in the middle.
Cheers,
Zach
Old 06-12-2011, 09:03 AM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
8' x 12' made out of 3 pieces of 3/4" plywood, shop grade, on 3 saw horses I built 3'-6" long. I can take it apart and move.
Old 06-12-2011, 09:10 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
I once had a fella suggest looking for some used pallet racks. They're relatively cheap and strong as heck. Generally consistent in dimensions and you can weld them together. Stick a few casters on it and it's mobile.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 06-12-2011, 09:53 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
Originally Posted by KnottyBuoyz View Post
I"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Well, you might have made it up, but I will be glad to recommend it to the "Classic Boat Proverb" thread - which I will go and start straight away !
Old 06-13-2011, 10:49 AM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
Originally Posted by Pylasteki View Post
Hi Guys,
Cheers,
Zach
Well... if you have the room and you go in for massive overkill, you could make your work benches the way I do. I build the tops out of 2x4's of the appropriate length, and assemble them side by side, until I have the right depth--like a humongous chunk of butcher block.
Instead of gluing them up, I pre-drill the 2x4's individually every two feet. Then I suck them together using lengths of 1/2" all-thread with countersunk washers and hex nuts. As the boards season and shrink, I tighten the all-thread. A little commonsense attention to alternating the grain and crown of the boards takes care of any warping issues...
I plane the bench tops flat, and generally protect them with sheets of Masonite or plywood (or even drywall at times), lightly tacked in place for easy replacement.
The supporting structures are usually 4x4 legs, on 4 foot centers. The legs are held together with 2x4 stringers notched 3/4" into place and fastened with carriage bolts, and the lower 2x4's normally support a plywood shelf for tools and miscellaneous.
I've never built a work bench over 30" deep. But I see no reason why the same methods wouldn't work at 48" or a little more, to accommodate full sheets of plywood. But decide where you want it when you build it, unless you have strong friends.
I've built this sort of work bench for other people, as well as leaving some behind when I moved, and I expect them to outlast the buildings they were placed in. They may well turn out to be my most enduring legacy.
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
Change a Flat or Not ! seamac Boat Design 0 10-13-2010 12:17 PM
Flat bottom/vertical sides/flat deck/ flat everything Ron Cook Sailboats 74 08-12-2009 08:51 AM
interior design work experience/work wanted schwing Services & Employment 1 01-18-2005 11:52 PM
flat paint daniel k Materials 0 06-27-2004 10:05 PM
Tools, Jigs, Benches, etc. Pat B Wooden Boat Building and Restoration 1 06-18-2004 12:34 AM
