The actual speed can be quite deceptive because most tend to relate big waves to high speed. I see waves as wasted energy. The attached photo shows a Hobie tandem competing in a 100m sprint. It averaged 10.2kph for the distance. This video shows my boat with a late model engine fitted just looping the lake at 12kph: http://www.boatdesign.net/forums/att...ats-jn_150.wmv It takes a minute or two to download this clip - almost 5Mb. The Hobies are durable and I believe reasonable value for money but they are slugs compared with most other paddled or pedalled boats apart from short sit-ons. Most people who buy them do not have experience in other boats and some get disappointed when they find they cannot keep pace with a small kayak. Rick W |
| Rick: I see what you mean about (hobie) inefficiency, white water all over the place and a big wake with roostertail to boot! Big contrast with your boat's minimal wake. I had the same experience with my sailing kayak which is a Crittur, 9.3 ft long, BWL 30" and shaped like a sharpened bathtub. Under sail in a goodly breeze I had to keep my elbows tucked in or the bow wave would soak them, it was halfway up up to shoulder height. Almost as stable as a dock though. Molded hulls designs are compromises, not made for speed. Not sure if I mentioned it in this thread, but I did not use an ama for the sailing kayak, I used a 1.5 sq ft Bruce foil on that, and it was very effective for cancelling heeling moment once I had the outrigger length and tilt angle right. Monster for leeway though.
| Rick - that video was great and I certainly know of no way someone's going to catch you on a calm day like that! Is that a home-made propeller system? Also, I meant to ask earlier if styrene pipe can be bent to shape using heat?Ak - Ive seen many types of sails on canoe/kayak. The lateen sail has traditionally been the choice for local fishermen in southeast Asia - easy to take down and out of the way while fishing. But I have seen balanced lug and other rigs used there as well. I decided to build one with 4mm marine plywood and chine logs (stringers). I'm going to use dual amas designed to provide flotation to match displacement - but not sure yet how to calculate that? Since I will be using a sail rig, I plan to install the arms just ahead of the mast. There are so many different designs being used for the ama itself. I'm thinking of placing them more forward so as to give more fishing space for rod use at the center and rear of canoe. What defines acceptable placement of amas with respect to lift, buoyancy, drag etc? Finally, what do you guys think of using a double-ended kayak paddle in an oarlock at the stern? Will it serve adequately as a rudder? I've found it's handy for turning the boat side to side or keeping it in line while drift fishing. I just leave it in the oarlock while attending the rod (like a traditional sculling oar . Newfie |
I have never used styrene pipe. Polystyrene is a thrmoplastic so can be formed with heat but if it is expanded then it will take a while to heat soak to soften it. Rick |
My first kayak sail was a square sail which rolled up over its spar and was hoisted with the paddle but was very small at 8 sq ft. The last sail I had was triangular and folded umbrella style in seconds but it was still small at 15 sq ft and short on performance. I am planning a 25 sq ft lateen on my next experimental effort but have not yet figured how to lower it easily and pack it away for paddling. That may be easier with amas however Quote:
ama displacement X outrigger length > wind pressure X sail area X CoE Having the amas well forward is usual for a kayak to facilitate paddling as well as fishing. That drives sail CoE placement which again is usually well forward. This is not optimal for sailing as it usually puts the sail too far ahead of the CoG. Note that a lateen sail with its CoE somewhat aft of the amas may have more potential for a capsize: this is less of a problem for me as I use Bruce foils which are easier to retract than amas. Quote:
| Rick - that's very creative work on your kayak with all the home-built parts! AK wrote: Quote:
AK wrote Quote:
AK wrote Quote:
![]() As you suggest AK, a foot operated rudder is practical and convenient,especially if you are fishing too. Newfie |
| For a rounded hull I’d prefer to use cedar strips which bend both ways. Ply objects to bending within it’s own plane. Unless the planks are very narrow they must be cut accurately as in the stitch-and-glue method or cut to fit by building over an accurate jig.
__________________ "Boats are like rabbits; you can have one boat or many, but you can't stop at two" - A. Onassis Boat designs: "a convoluted collection of discontinuous compromise" - Par ". . . ere the end, some work of noble note, may yet be done . . ." -Tennyson Dances with Turkeys Last edited by ancient kayaker : 01-26-2009 at 01:15 AM. Reason: typo |
| Ak - as you note, plywood is more difficult to 'twist' to fit, so I guess that's why it is more applicable to hard chine hulls. I was actually planning to use battens and install ribs first (more of an east coast method), in which case the narrow plywood strips should bend enough to tack to the ribs before gluing seams. However, since we're on this topic, you mentioned 5 plank method. If one was using 10 planks to 'approximate' a round hull (more smooth chine hull), would not the plywood planks bend to fit on stringers just as well as gluing them to chine logs and then bending them? Since cedar is getting more expensive here and less quality, would western spruce be a reasonable alternative? I ask this because eastern spruce is widely used for round bilge hulls in small boats in Atlantic Canada? By the way, the 'tacking amas' was bit of an offbeat question, but what do think theoretically? |
I didn’t pick up on the tacking amas first time I read you post: it should do the same thing as an idea of mine- The Articulated Sailboat -which would use Bruce foils instead of amas; for my design I plan to mount the outriggers and mast on a turntable; using a lateen sail theoretically results in the sail automatically taking the wind on the other surface when the turntable is rotated. It leaves the hull unrotated of course, but as the sail/mast/amas move along the new heading it should fall into line with the aid of a fixed skeg.
#25
| Well AK, that poses some some interesting issues. One would seem to be a force choice into either strip-plank with wood, or stitch and glue plywood. That's a decision I'll have to make. However, in some situations one could use a combination of both. I say this because some Pacific islanders actually employ both , even today, i.e. hollowing out a log to get the below waterline round raked hull and continuing with mortised ribs and plywood for the upper sections. If your planks are same width as 4mm plywood, then both can be used; especially if the thing is going to be painted. Take your idea of a 'turntable' for masts and amas. I've never seen such a thing but it sounds innovative. Is this your own creative design? Are you going to build without an engineer's plan? Just curious Also, have you ever seen amas made out of a discarded foam-sandwiched surf board and would such a thing work? Maybe I should be specific re the 'close to' rounded hull on a sailing canoe. If a beam measure at waterline was say 24" at midship and the depth of displacement below the water line was say 6" at the keel line, what number of plywood strakes would be "reasonable" to achieve said 'close to' round bottom, without pushing the plywood into 'fracture mode'? Newfie Last edited by ShagRock : 01-27-2009 at 06:41 AM. Reason: typo |
#26
| Certainly cedar-strip and stitch-and-glue with plywood are the most popular construction methods today, but you still have plywood plus chine logs. Hybrid construction is also a possibility which can give the boat rounded below underwater shape with the simplicity of ply from the waterline up; the interface between strip and ply may be a challenge. Do you need/want the rounded underwater shape that much? There is not a great deal of difference in performance as Rick noted in post #14, and I suspect it is more of an issue with monohull design where the stability has to come from beam and hull shape rather than the amas. Rick say his boat is a "pure speed machine" and it looks it, but his first picture showed a flat bottomed hull, very easy to build and you might not notice much difference in performance. The 'turntable' for masts and foils is my own design, of course there's little new under the Sun so someone may have already tried it, but if so I haven't found any information on the attempt. Being an engineer, although long retired, I am incapable of building without a plan but it has to be tailored to fit the kayak so I will build it more or less around the boat. There's a bit of science in the thing but I try to get out of old habits these days. I haven’t seen amas using bits from foam-sandwiched surf boards but I imagine it would work rather well. The hard part would be the joint with the outrigger. It’s not the beam and draft that determine the number of bottom planks required so much as how ‘round’ you want it to be. Using cedar strips allows you to round off the corners between the strips to achieve a round hull. You can’t do that with ply or you may remove the outer veneer which is responsible for much of its strength. If the amount of thickness you are prepared to remove is T from a strip of width W on a hull of radius R then: W = sqrt (8RT) For a half-round hull bottom 24" beam, using 1/4" thick cedar strips and restricting thickness loss to 0.05" allows you to use 2" wide strips, but with 4 mm ply you should not take off more than 0.01" or 20% of veneer thickness so plank width is limited to 1", requiring 38 planks. Handling 38 ply planks 4 mm thick and 1" wide is going to be far more difficult than 19 cedar strips 1/4 x 2". If cedar is costly, I know of no reason why a cheaper wood cannot be substituted provided it is reasonably light and straight-grained, fairly knot free or with small tight knots, glues well and is easy to work. The major cost in cedar strip construction is the milling of the strip edges, if you can do that yourself cost is reduced by an order of magnitude. That being said, I still think a simple rectangular-section hull will be adequate and easier, faster and cheaper to build, especially if the amas are made using the same construction method.
#27
| AK - I suspected you were an engineer and it shows in your well reasoned response - just excellent! Thanks so much for the math based analysis regarding wood, plywood and relation to build shape. AK wrote Quote:
AK wrote Quote:
AK wrote Quote:
AK wrote Quote:
I'll re-check the cedar option at a specialty cedar store as opposed to big box store, but I could use spruce anyway. The cedar could look good matched with South America mahogany plywood. I could also use the ply for decking. I'm hoping to have a 'track saw' by the time I start this project which should make stripping my own planks easier. I don't know if you or others have used one for boat building purposes? The winds of indecision are starting to abate! Newfie |
#28
| I must admit I hadn't heard of a track saw. I'll pass on some tips that might help. My method for cutting up a large sheet of thin ply is to use a 3-1/2" circular saw (the "precision saw" from Canadian Tire in my case). I lay the ply on a cutting table that is topped with a sheet of 1" insulating foam to protect the blade and the table. I use a regular 7-1/4" circular saw for stripping planks, also on top of the cutting table, with a thin kerf finish quality blade (cost as much as the saw!) and a home made guide which extends at least a foot either end of the saw foot plate to ensure the start and end of the cut remain straight. I fit a ply plate under the foot plate of the saw and drop the blade through it while running to get a zero clearance slot. I prefer a hand saw to a table saw for cutting long planks as the workshop has to be more than twice as long as the plank with a table saw, something I cannot always guarantee. A hand saw is not quite as accurate but I can easily keep thickness variations below 1/64" which is adequate for most purposes. Good luck! Don't forget to post the pictures.
#29
| Newfie: I can't get those elegant boats of Rick's out of my mind! A hard chine "square" hull is much easier to build than a half-round bottomed hull. Here is my take on the construction of a compromise hull with quarter-round chines. It would be really easy to build, pretty and maybe just a hair faster than a square hull due to reduced turbulence. Basically it just consists of cutting square and rectangular section strips off a plank of clean wood of a split resistant kind such as straight-grained poplar and gluing them to ply planks in the order shown in the figure. The chine would be of constant radius, and each stem foot would turn out with a rather nice elliptical profile and a sharp entry.
| Seaworthy Kayak ????? | Frosty | Open Discussion: All Things Boats & Boating | 19 | 02-08-2011 11:50 PM |
| tiny trolling motor for kayak/canoe fishing | srimes | Propulsion | 13 | 01-02-2009 12:29 PM |
| Greenland kayak | novak28 | Open Discussion: All Things Boats & Boating | 0 | 09-18-2006 07:44 PM |
| aluminum Kayak | RDB | Metal Boat Building | 14 | 04-24-2006 10:53 AM |
| kayak on foils | nico | Boat Design | 6 | 05-29-2005 03:11 AM |
