| Fishing/Hunting pontoon boat I want to build a pontoon boat that can be broken down without much hassle and transported in my van... I am planning to fish and use it as a blind for hunting... I want it to be somewhere in the range of 8' long and 5' wide... does anyone have any ideas... what I have so far is I will get some ventilation tubes and seal and fill them with foam for the floats and make a wooden plat form to bolt to them... I will also be using a small electic motor on this... if anyone has any ways I can improve upon this or do something differently please let me know... Thanks Brandon |
| Now I am thinking for the pontoons to just buy foam from HD and layer it to make it a foot thick then cut out the shape and fiberglass it... what do you guys think about this and how would i go about fiberglassing it... Thanks Brandon |
| I would laminate a good stright piece of ceder for a backbone in the pontoon made of laminated foam for strength and also provides an attaching member for your deck rails and deck. . Glassing foam can be done with epoxy resin NOT fiberglass resin. FG resin will melt the foam . Epoxy is not cheep . Another option would be to Rhino line the pontoons It will protect the foam and easy to repair if needed . The repair would be to use an expanding foam in a can to fill the ding sand smooth and re apply some Rhino liner . The GOOD thing is no matter what , it wont sink. ![]() |
| Fiberglass fishing boat re-do | SRSACAT | Fiberglass and Composite Boat Building | 1 | 05-24-2007 12:23 PM |
| duck hunting boat?? | hoobilly | Boat Design | 8 | 11-18-2006 08:01 AM |
| Fishing Boat | FishingRod | Materials | 3 | 06-09-2004 02:31 PM |
| Traditional fishing boat? | Doug Carlson | Powerboats | 28 | 10-21-2003 08:51 PM |
| 18 ft forecast fishing boat | Guest | Boat Design | 0 | 07-07-2003 01:25 PM |
