| first time boat builder. considering houseboat so i'm 24 and in a wheelchair. recently i had some things in my life that made me want to pursue a more free form of life. that came to me in the form of wanting to try the houseboat life. with needing to keep atleast a 30" gap for my wheelchair here's my layout with the front to the left of the pictures. i just based it on a 20' by 8.5' pontoon platform. drawn to scale in autocad. 4' deck, 14 foot quarters, 2' rear deck for generator/propane etc. oh, and i kept the highest counter at 36". not only because i'm in a wheelchair, but because i think being able to see out every corner from everywhere makes it more open. sorry for total noob status so starting from scratch i know i need to figure out all of these things: temp-insulation/windows engine i know nothing about any of this. well, starting to learn. the one thing i'm most wondering about is the price range i'm looking at. power: for the kitchen, i just need to figure out power consumption for fridge, microwave. + any lighing on boat and entertainment consumption. wiring for 12/110 structure: what materials are best for construction of walls, roof, insulation, etc w/ weight & cost in mind. never done anything w/ boats before but did my share of home upgrades and working on cars. my question is this. knowing i have to keep it as light as possible what would be the best material for floor, walls, roof, and joists? ![]() |
| The first thing you need to do is establish a SOR, then preform a rough weights estimate so you know how much hull(s) you need to hold all this up. Of course, this assumes you have enough engineering and hydrodynamics ability to process the information and apply it as best as you can to you SOR. Considering the very basic nature of your questions, you aren't skilled enough to "design" a houseboat. This isn't meant to offend you, not everyone can, in fact very few can, so you're in the majority in this regard. Buy a set of plans. Modify the inetiour arrangements to suit your needs, but the best advise anyone can offer you is to buy a set of plans. Start here: https://www.boatdesigns.com/Houseboats/departments/7/ |
my plan was to calculate weight and the balance of the weight. once i figured that out i was going to try and figure out the size pontoon needed and if it seems possible on my budget. |
| Have a look thru this subject thread Retirement Houseboat or Floating Home ...and have a look at this builder in GA Retirement Houseboat or Floating Home Aqua Lodge ...likely they could build one for you |
| You should consider building the painter[dinghy] first, to see if boat-building is your cup of tea. Those results should be enlightening, to say the least.
__________________ Hoyt The TITANIC sank because it had a hole in it(still does). Submarine Tom You just can't put too much info on your patterns. DGreenwood |
| A few questions from a 1st time Catamaran builder | Greyhaven7 | Boat Design | 1 | 10-19-2008 03:56 PM |
| Need help, First time boat builder | justinfitz1 | Boat Design | 12 | 01-12-2008 10:35 PM |
| First time alum boat builder with lots of questions. | Bob boat bldr | Metal Boat Building | 5 | 11-14-2006 10:28 AM |
| First time boat-builder | timplett | Boatbuilding | 46 | 08-18-2006 10:49 AM |
| First time boat builder | Greg in Atlanta | Wooden Boat Building and Restoration | 14 | 11-29-2004 01:29 AM |
