Old 04-07-2008, 10:57 PM
ondarvr ondarvr is offline
Rep: 226 Posts: 633
You can get cardboard with only one side, this lets it conform to a curve. Carboard boxes have a corrugated layer between 2 flat sheets so it's stiff, with a flat sheet only on one side it bends easily. It comes in rolls, check local paper supply companies for it.
Old 05-02-2008, 06:27 PM
BWD BWD is offline
Rep: 128 Posts: 228
I think you could also start wrapping your male mold with just a couple layers of 6oz E, key it after cure while still on mold, then slit it with a tool of your choice. Might want to peel it off and throw a more release under it, then put it back on, lay up the rest over it. Having a cured and ever-so-slightly expanded base layer may solve mold sticking problems. ...
How big an engine is too big for my motor sailer rileyatsea Inboards 6 12-21-2010 08:09 PM
RIB Tubes percepts Services & Employment 0 10-17-2007 10:10 PM
Inflatable Tubes dweymer Fiberglass and Composite Boat Building 5 11-13-2004 09:47 AM
Flotation Tubes nightz13 Materials 1 09-07-2004 04:55 AM
foam tubes? Psycho D Materials 1 07-12-2003 01:52 PM
