| Fiberglass Hull Repair (Rookie!) Hello! Just bought a '97 Reinell 185, & on my second day out I got a puncture in the hull.. :| it's pretty significant at about 7" length, the boat wasn't taking on a noticeable amount of water but it's definitely punctured through. (No structural damage evident or suspected). The labor cost for fiberglass repair is (as you all know) fairly high, I'm just looking for any opinions out there about how big of a fool I would be to patch it myself. I have time, I'm bright & patient, but I want to know if this sizeable repair might be something I can do right my first time around. I'm reading up on options, not going to Bondo it but I've seen the Duraglass option, is that sound enough to be used on the external body below the waterlinej, any advice will be hugely appreciated! Uploading photos.. Tl;dr. Punctured hull, 7" length, no fiberglass experience.. Pay the pro's or can I do it myself with the right research & patience? Thank You! |
| Photos of the Damage ![]() ![]() ![]() ![]() |
| Do you have access on the inside to the damaged area? |
| of the photographs appears that damage is not great. Can you fix it yourself. rub well point to 100 grit and put 2 layers of mat 600. completely dry after you cross the damage a hand gels coach. on this point put a slide and press.after 12 hours take it off.you will be surprised
__________________ m3mm0 SR ib http://www.youtube.com/watch?v=5kwlNk7-iSg |
If I understand you right, you're saying that after prepping just two layers of mat 600 would be enough? Anyone else agree? |
| Rookie repair. Fiberglass floor repair | uffdabock | Boatbuilding | 6 | 08-09-2011 06:24 PM |
| Fiberglass repair | John Hanafin | Fiberglass and Composite Boat Building | 5 | 01-23-2010 01:11 PM |
| Fiberglass repair shop/ boat repair For Sale. W/ property on US1 | boatguy64 | Marketplace | 1 | 03-03-2008 01:23 PM |
| Fiberglass Repair | DJMOBILEFIBER | Services & Employment | 0 | 05-21-2007 10:41 PM |
| Structural Repair of Fiberglass Hull | Randytea | Fiberglass and Composite Boat Building | 8 | 10-07-2004 05:32 PM |
