| Fiberglass box I need some help making a fiberglass box. I want to make the box out of plywood and then hand layup the inside of the box. I need to have a inexpensive way of getting the wood separated from the fiberglass box when the fiberglass cures? I don't want to make a mold and use releasing agents. Its a kinda big box 3'x4'x7', This is a one time deal. Is there any cheep way of doing this? Thanks for any help you can. Jackie |
| Cheap--->Instead of ply wood use ordinary kitchen self, material the white stuff laminate, normally nothing is needed if it is new an unscratched, for a single quick job, remember the seams would be the place where it sticks, but just hamer the mold apart. |
| what kind of finsh do u want , the laminated wood works well but costs$$$, i often use drywall board all u need is a knife to cut it and duct tape to hold it all together for the inside you will want to line it with some mylar use 3m 77 spray glue to stick it down for the corners use some scotch tape to make a nice round corner or use plastersine and a dime to round it off, with mylar u will not have to use wax , i dont know what finsh u want if looks are not that inportant lay up the fiberglass on the outside and finsh with a coat of gelcoat with some wax added to seal and let it dry hard , this way the inside will have the smooth finsh I would go this route if its going to be use as a vessell or tank |
| kitchen self Thanks for the help. Richard, I am not sure what you mean. Are you thinking of the Kitchen Cabinet Countertops Laminate countertops? Jackie |
| Jack, It doesn't matter what it looks like. I would like to know more about mylar u ? Whats the cost to cover 100 square feet or so? Where do you suggest I get it on line? Thanks Jackie |
| well if your not worred how it looks go to the supermarket and buy some rolls of wax paper its cheap and stick it to the drywall with spray glue just for piece of mind fire a couple of staples in to around the corners and cover with some tape you will not need to wax the paper when the glass is cured u just have to rip the dry wall out and pull the wax paper off this is the cheapest way to make a mould for a one off |
| Jack, I want to thank you and Richard for your help. Jackie |
| You can also use aluminum tape- the stuff that the hardware stores sell for taping up ductwork. I'm not talking about dcut tape, mind you, but something more like tinfoil with a sticky peel-stick side.
__________________ Are we off-topic yet? |
| Jack and Richard, I am back I just was told that we have a problem. At the bottom of this fiberglass box off to one side is a 10" pipe that has to be sealed not to leak. We have to cut a hole in our new fiberglass box and then seal around the pipe. The pipe is a rusted cast or steel pipe. We need a good bond from fiberglass to this rusted steel? This pipe is about 3/16 thick so we can grind to clean it up. Jackie |
| aluminum tape Toot, I recieved aluminum tape as a posible use, Thanks Jackie |
| A Beautiful Box... | Sean Herron | Boat Design | 4 | 07-05-2006 08:44 AM |
| alternative to stuffing box? | need-help | Boat Design | 2 | 03-23-2006 10:34 AM |
| CD box blown? | revshot | Outboards | 9 | 02-24-2006 04:40 PM |
| New Orc BOX Ruels | MrK | Sailboats | 0 | 08-04-2005 12:03 PM |
| Engine gear box | Guest | DIY Marinizing | 11 | 10-23-2004 07:34 PM |
