| Fiber glass repair question Hi I have a boat that I am trying to repair. It HAD a crack running 90 degrees across a lifting strake. It seems there was a substantial air void in the strake from when the hull was laid up with no putty or fillers in the void area and has some delamination. The cracked started right at a bulk head inside the hull that has created a hard spot. My question is: there is no access from inside the hull due to huge center console, decking and a false subfloor. The crack has been ground out and it has opened a silver dollar sized hole in the bottom of the hull. Would you feel comfortable making a repair entirely from the underside of the hull. Thank you |
| Yes . . . |
| Thanks Par |
| Fiber Glass/gel Coat Help | down2lb | Fiberglass and Composite Boat Building | 13 | 05-08-2010 07:47 PM |
| 18 m fiber glass hull for sale (new) | Nabil | Marketplace | 0 | 07-12-2008 04:08 AM |
| cold moulding vs fiber glass | nautical | Wooden Boat Building and Restoration | 21 | 05-13-2007 10:48 AM |
| Weight of fiber glass | jfblouin | Fiberglass and Composite Boat Building | 10 | 07-14-2005 10:30 AM |
