| Fairing Core cel bead and cove I have a 17' hull planked in 1/2" core cel, I have been longboarding it and it goes well , I was looking at someone else who is doing the same and knocking down high spots with a 8" round sander your thoughts? |
__________________ Slippery when wet. www.cheetahcat.com |
| Dito, you can't fair a hull with an orbital sander, you have to longboard. This said, if you are quite skilled with a DA, you can knock the tops off high spots (after their identified), but ultimately leveling these will require the longboard. |
| Thanks She is a very shaply hull and I have her very close to fair on the jig the planks I used are 2 1/2" should not take too long! |
| Just to chime in, the local bottom guy here (who is also the equipment guy for the US Olympic team) uses a orbital sander, and an electrical planer on really bad bottoms. But then he also cuts out templates with a sawz saw. Of course all of this 'rough' work is then followed up by hand long boarding. The reality is that if you have the skill, and know exacally what you are doing, you can use pretty much any tool you want. But the more agressive the tool used the larger the likelyhood of taking off too much material, and having to start over. Personally I use long boards and if the work takes more than that it goes to a pro.
| Orbital sanders follow too closely to the surface to be effective at knocking down high spots. These sanders are finish sanders and intended to smooth the surface, not fair it. There's a huge difference between smooth and fair. Smooth is something you can feel, on the other hand, fair is something you can see, though unskilled hands can't feel it (skilled hands can). You can have a really smooth, but unfair surface, like slightly wavy, but clean glass. If you use an orbital or DA sander, you'll get a smooth surface eventually, but it will not be fair unless you have way more experience then I. |
| This has looked good to me for a long time - I reckon I will buy some to try soon http://www.flexicat-tools.com/ |
| Yes, these are great. For initial high spots: take something light and straight (such as an old fluorescent light) and shift this over the surface, holding it in the middle. At high spots the FL will tilt. Mark this spot with a pencil. Work the whole boat that way. Now you have the boat marked wil pencil, and you can sand those marks. Leave the rest alone for the longboarding. This at least saves some time and effort.
also have an old electric half sheet with a metal plate for a base pad it sands dead flat, Hutchins Straight line, DAs ,Rasper ,Eliminator, and the common 8" DAs with different pads. Nothing comes close to a large Metal file in the right hands.
| Im kind of partial to fartrock and its very cost effective,of course you still need skill. Oops,your not going to be using fartrock on the core,sorry. Steve. |
![]() All the best from Jeff. |
| Great Cove 21 | chippah | Boat Design | 0 | 01-18-2009 02:53 PM |
| bead and cove bits | shark | Wooden Boat Building and Restoration | 1 | 05-29-2008 10:59 PM |
| bead and cove strips | Dijkhuizen | Boat Design | 52 | 11-03-2007 12:16 PM |
| Bead and cove technique / Bilodeau book | sailsocal | Fiberglass and Composite Boat Building | 0 | 09-09-2006 01:46 AM |
| bead and cove stripplanking | trimix | Boat Design | 3 | 10-23-2004 12:01 AM |
