| Fairing block for helm chair Hello guys.... New member here, with a question. I want to install a companion helm chair on the flybridge of my vessel (42' Post). The deck slopes to starboard and aft. Is there a technique to form a fairing block for the pedestal to be level and plumb? I started out with a piece of teak and the sander. Now, I'm close... about 1/16" of adjustment. After final fit, a 3/4" piece of starboard would be used between the base of the pedestal and teak fairing block. I now have a piece of 1.5" white starboard, I would like to make the fairing block out of this. This same thickness would be used as a backing plate. Again, there must be an "old school" method to make the block. I have seen, numerous Posts', that added the companion chair, leaning to starboard and aft. I'm looking for level and plumb. Thanks in advance.... Capt. Hank |
| Cast it Not exactly "Old School" ![]() You could lay down a barrier then build a fairing block of thickened epoxy. The West System manual shows the technique for building up mounting pads for winches etc. Once the epoxy has set you could finish it and use it for the fairing pad or as a mould to lay-up a fibre-glass fairing piece. How is the main helm seat mounted? Could you duplicate that on the other side?
__________________ "Those who fall in love with practice without science are like a sailor who steers a ship without a helm or compass, and who can never be certain whither he is going" Leonardo Da Vinci |
| Thanks for the reply... I had thought of using that method, but.... didn't think about the barrier. I didn't want a permanent block on the deck. I was thinking of using a round cake pan.... build up the epoxy, till full (trying to keep things level on all axis. If I can make things level..... cut to final thickness with a band saw. |
| Hank, A sharp low-angle plane works well in polyethylene. Yoke. |
| Use a piece of thin panel or 1/4" ply as a template. Hold (with a helper) the panel level (use your eye, bubble levels ain't much good on a boat!). With a pair of dividers, kid's pencil compass, wood block, whatever, run this along the deck, thereby scribing the slope onto the panel. Cut out the slope from the panel, then transfer this to your fairing block.
__________________ Craig Cavanaugh Silver King Custom Marine No shoes, no shirt, no problem! |
| Thanks guys.... I cut the bottom out of a 5 gal pail, about 4" high. Layed down a layer of duct tape on the flybridge deck, tacked the bucket ring with "super glue". Used clay to seal the bucket to deck. Mixed 2 part, low viscosity epoxy, with fiberglass beads and fibers. Poured into ring, tapped the sides to level, let sit for 48 hours. One hell of an exothermic reaction for the first two hours. Didn't harm the deck. Level and plumb on all axes. On top of this a 3/4" thick, piece of starboard. Used a drill guide to drill the 21/64" mounting holes for the pedestal. Using a 1", thick, piece of starboard for backing plate. A bead of 5200 around all of the holes and epoxy ring after painting. |
| new capt on the block | drbrooks | Wooden Boat Building and Restoration | 2 | 03-09-2006 06:12 PM |
| Volvo block number | PJC | Propulsion | 1 | 12-03-2005 06:03 PM |
| Gamefishing chair CAD blocks | Willallison | Software | 3 | 11-16-2004 04:03 PM |
| Rhino drawing of Racing Chair and Machine Gun | Vibtor | Boat Design | 1 | 10-03-2004 07:05 AM |
| The helm | duluthboats | Boat Design | 1 | 10-30-2003 03:36 PM |
