Old 02-14-2008, 01:35 PM
steamer steamer is offline
Extending casting deck
Rather than buy a new boat, I think I would like to fix up my older one.
I have a Kenner 17' pro skiff, It has a small front deck on it, and I would like to make it a few feet bigger. The deck that is there now is plywood on the inside and fiber glass on the out side. Could I build a extention out wood/plywood, then cove it with fiberglass, and then repaint? Here'e a little drawing to explian it better. BTW, I have not fiberglass experiance, Is there a 'How to" on the web somewhere?
Old 02-23-2008, 05:28 AM
Rep: 66 Posts: 640
Yes, you can extend the deck in the way you're proposing and I'm sure you can find a thread on 'how to' in this forum. Just remember, for a good adhesion you should use vinylester or epoxy in stead of polyester!
good luck
Dutch Peter
Help extending? Matt.D Boatbuilding 47 12-14-2007 10:22 AM
Extending Stern shaftlog Metal Boat Building 11 07-23-2007 02:16 PM
putting casting deck in a tri-hull mkkoyboy69 Fiberglass and Composite Boat Building 1 04-27-2006 04:38 PM
making a casting deck livetofish31 Fiberglass and Composite Boat Building 1 03-12-2004 07:59 AM
extending the transom Guest Boat Design 9 10-10-2003 07:40 AM
