Old 01-19-2007, 10:48 AM
mkpardy mkpardy is offline
Rep: 10 Posts: 6
epoxy vs polyester resin
i'm a new member and would greatly appreciate any input.
i'm looking at building the console skiff and polyester resin and cloths are
easily attained becuase there is a boat building shop about 2 minutes from my house.i have fiberglassed a couple of boats in the past but never a stitch
and glue. the polyester seem to have worked ok but i'm wondering about
strength,delamination and the number of layers i may need to apply.
i live in nova scotia and we sometimes get a decent chop in the water
3'to 5'. any input
thanks kevin
Old 01-19-2007, 12:44 PM
RatliffFranklin RatliffFranklin is offline
Rep: 17 Posts: 191
Boats are so overbuilt compared to airplanes or racecars I'm not sure if the comparative strength of epoxy versus polyester really matters.
Old 01-19-2007, 01:30 PM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
The strength doesn't matter quite so much as the adhesion and waterproofness (is that a word?). Polyester doesn't adhere to plywood as well as epoxy, nor is it as waterproof. Polyester is also more brittle and may crack with the flexing of the hull panels, whereas epoxy will flex with the panels while staying stuck to the wood (keeping it sealed). Any EXTERIOR application of resin should be of epoxy. Fillets and taping should also be of epoxy. You might get away with coating the interior panels with poly. Epoxy will glue Poly but poly will NOT stick to epoxy with any strength so bear this in mind...fillet areas should be left at bare wood for the best adhesion of the epoxy. The number of layers (of glass I presume) are largely dependant on the purpose of the glass...if it is structural, then a layer of roving, a layer of matt then a layer of cloth would probably do...depending on how thick the plywood and how big the boat. If the FG is simply for abrasion resistance then one or two layers of cloth should be sufficient...again depending on the size of the boat and how many rocks you intend on denting.
So...What are you building?
Steve
Old 01-19-2007, 01:53 PM
Rep: 10 Posts: 6
polyester resin
thanks for input. i'm thinking of the glen l console skiff 15'6".
what if i used 24oz roven as a layer along with a few layers of
mat on the exterior and 2 or 3 layers of mat on the interior .also did i mention that poly resin is $28 gallon and epoxy is
about $135 gallon. what do you think.and again thanks for the input
its greatly apprecieted
Old 01-19-2007, 02:02 PM
Rep: 17 Posts: 191
Pricing
I don't know what taxes and import regulations are like in Nova Scotia, but have you looked into the possibility of getting your epoxy resin by mail order?
www.aircraftspruce.com
Old 01-19-2007, 04:22 PM
SamSam SamSam is offline
Rep: 464 Posts: 1,608
Do what the plans tell you to do. With 5 layers of mat and 1 of 24 oz wr, that's what some pure fiberglass boats are made of, without the wood. The plans call for 1 layer of 7 or 8 oz cloth on the outside only. That's 7-8 oz per square yard. Your 5 mat plus 1 wr equals 91.5 oz per square yard. And that's just the cloth, not the resin also. Sam
Old 01-19-2007, 05:47 PM
lewisboats's Avatar
Obsessed Member
Right-O..
Are you building an GRP design or Stitch and Glue? What do the plans say and what is the boat? With a layup like that you don't need the wood but you will need a mold...and a crane.
Steve
Old 01-19-2007, 10:32 PM
LP's Avatar
LP LP is offline
Rep: 370 Posts: 640
I couple of other places to look for epoxy.
http://www.raka.com/
I've heard good things about the 350 resin. Good for clear coats. My current product. Tends to "go off" slowly.
http://www.uscomposites.com/
Tends to blush, but has a good working life and "goes off" quickly.
Less expensive than West System and some others.
LP
God bless the open minded people of the world. LP
Old 01-20-2007, 09:01 AM
tom28571 tom28571 is offline
Rep: 1424 Posts: 1,649
The epoxy/polyester subject has been covered ad nauseum. There is a clear result and it is epoxy for a wooden boat. No point in restating all the many reasons here and this is a no-brainer.
Tom Lathrop
Old 01-20-2007, 11:28 AM
mmd's Avatar
mmd mmd is offline
Rep: 290 Posts: 378
If a plywood stitch-and-glue construction project, it is as tom28571 says - a no-brainer. Polyester does not adhere well to wood and will allow moisture penetration, both disasterous to the longevity of your boat. Check out the comparitive costs of System 3, East, West, and MAS epoxies - I think that you will find East System is probably the best price locally. Don't go overboard with extra laminations of cloth; unless you re-engineer the structure to determine a lighter ply you are merely adding weight and cost.
Hope for the best, but plan for the worst.
Old 01-20-2007, 06:22 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
"Stich & glue" boat plans came on the homebuilt scene AFTER epoxy started being used. Hmmmmm?
Not just strength, water resistance, but..... forgivness. Make a mistake with epoxy and it still gives good results. With polyester you have to be spot on. It's a pros material.
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Old 01-23-2007, 11:23 AM
Rep: 10 Posts: 6
epoxy it is
thanks for all the input guys, i really appreciate it.
I will be using epoxy (east) for my project boat.
Polyester resin problems. zoso Wooden Boat Building and Restoration 9 10-18-2006 09:39 PM
Polyester resin roko Fiberglass and Composite Boat Building 10 11-28-2005 08:39 AM
polyester resin shelf life Ssor Fiberglass and Composite Boat Building 3 02-24-2005 07:58 AM
Polyester Resin Floor Coating FishTales Materials 4 09-26-2004 10:45 PM
epoxy or polyester resin gbaaron Powerboats 2 06-20-2004 09:52 PM
